98 ZJ Back diff grinding while turning - JeepForum.com
post #1 of 15 Old 05-06-2013, 05:55 PM Thread Starter
shaynesaw
When I turn either direction I hear a low pitch grinding sound coming from the back axel area.
It gets worse the sharper I turn. Seems to be a lot worse when accelerating while turning.
I haven't looked to far into it because I just noticed it but any thoughts? possibly no fluid?
Can anyone help in this matter?
shaynesaw is offline
post #2 of 15 Old 05-06-2013, 06:37 PM
durango-bob
2006 WK
Bad wheel bearings would do that. And they go bad in short order when you run low on Diff fluid.
durango-bob is offline
post #3 of 15 Old 05-06-2013, 09:39 PM Thread Starter
shaynesaw
Thankyou kindly
post #4 of 15 Old 06-09-2013, 10:40 AM Thread Starter
shaynesaw
So I changed the back wheel bearings and inspected the diff condition. Diff looks mint.
I'm still getting a grinding at the rear end when I turn either way. It doesn't seem to do it until I've driven it for a bit and everything in warm.
Any thoughts?
post #5 of 15 Old 06-09-2013, 12:23 PM Thread Starter
shaynesaw
Part store guy suggested synthetic gear oil and posi-track antislip additive.
Will try that
post #6 of 15 Old 06-09-2013, 02:06 PM
lil_joe
If you Have the tow pkg, it could be your LSD
Mike
____
lJeepl
--[.]IIIII[.]
Obsession is a word the lazy use to describe the dedicated
HER's: 92 YJ 4" RC 1.5 RC Booms, 1" BL on 33's
MINE's: 97 ZJ 5.2 Upcountry Limited Project 2" RE BB on 265/75 Mud Dogs, Locked front LSD rear, 242 swapped T-Case, RC Quick Disco's
lil_joe is offline
post #7 of 15 Old 06-09-2013, 02:14 PM Thread Starter
shaynesaw
I did have the tow package but removed it.
Is the dana 44 a LSD?
post #8 of 15 Old 06-09-2013, 02:19 PM
Timo_90xj
Timo_90xj's Avatar
Not necessarily. However, since your bearings are good I would also suspect the limited slip clutch packs. They tend to go bad within 100-150k miles, sometimes even less if wrong type of gear oil was used. If they are bad, you need to replace the packs to make the grinding go away. Use spicer replacement parts.
I'd strongly suggest using the Mopar limited slip friction modifier whenever changing gear fluid in the rear. That is, if you have a limited slip rear.
***Under construction***
Timo_90xj is online now
post #9 of 15 Old 06-09-2013, 02:31 PM Thread Starter
shaynesaw
Can you tell if its LSD by this picture?
post #10 of 15 Old 06-09-2013, 02:58 PM
PolkaPower
That is a limited slip carrier.
PolkaPower is online now
post #11 of 15 Old 06-09-2013, 02:59 PM Thread Starter
shaynesaw
I appreciate the help
post #12 of 15 Old 06-09-2013, 06:40 PM
dusterdude
Polka,im used to seein clutch packs in the lsd carriers,how can one tell that one is lsd
dusterdude is offline
post #13 of 15 Old 06-09-2013, 07:07 PM
PolkaPower
The shape of the carrier. Here is a open and LSD.
post #14 of 15 Old 06-09-2013, 07:31 PM
HOSTED67
Changing the fluid and adding friction modifier is a cheap and easy thing to try first. Drive it for a while and see how it does. The noise could go away after the new fluid and friction modifier work into the clutches.
ASE Certified Master Automobile Technician and Master Truck Technician
HOSTED67 is offline
post #15 of 15 Old 06-09-2013, 07:46 PM Thread Starter
shaynesaw
Thanks for the picture comparison.
I will change it tomorrow and see what happens
