98 ZJ 5.9 overheating? - JeepForum.com
post #1 of 6 Old 02-09-2009, 09:44 PM Thread Starter
Texas98ZJ
All,
First post! Need a little assistance here, my 98 ZJ 5.9 was consistently running 225 with the fan beating itself to death; but the temp never went higher. I noticed the upper radiater hose was pretty easily squished in my hand, but the lower was stiff as a rock. I thought radiator! The radiator is original and now has 140k miles on it. I pulled the radiator and it was in BAD shape, so I replaced it; filled it and burped the system several times. The upper radiator hose is now hot, but still not very firm to the squeeze; and temps are running right at 210. Lower hose is much harder than the upper. Problem? I told a mechanic to put in a 180 while in San Antonio because I spent a TON of time stuck in traffic. To me that means I shouldn't go above 180. SO - BOTTOM LINE : should the upper radiator hose be stiff to the squeeze? Would a non-hard upper mean the tstat is stuck closed? I'm now in El Paso and for those of you who know - it gets HOT HOT HOT down here in the summer and I don't want to be overheating. TIA for any help!
Rob
Texas98ZJ is offline
post #2 of 6 Old 02-09-2009, 11:49 PM
-cAcHe-
-cAcHe-'s Avatar
water pump? my upper hose is kinda squishy also...i have a 180 T stat on mine with an electric fan and it stays around 195 in the summer...those 5.9's have the electric fan right..maybe the an is going bad?
Originally Posted by CarolinaWK View Post
I like happy endings :2thumbsup:
RIP Troy Edwards (bigbluezj94)
-cAcHe- is offline
post #3 of 6 Old 02-10-2009, 12:39 AM
Colorado 5.9
Colorado 5.9's Avatar
If it's running at the 210 mark then that's about normal on a warm to hot day.
The fins on the pump might be worn down a bit do to cavitation. Especially if it's never been replaced.
When it's running though the upper hose should be tight. I'd try a new termostat first. Make sure you have a new cap too.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #4 of 6 Old 02-10-2009, 12:46 AM
97ZJMAN242
the lower radiator hose is harder to squeeze because theres a spring like shape former that is stronger, takes more of a beating down there, the upper is squishy because its just the hose. but i would replace the tstat first simply because its around 5 bucks with a gasket....if its not it, it wasnt that expensive and you know its good...
if that doesnt solve your problem since you already replaced your old worn out radiator. i would def check your water pump.
97 ZJ. 5.2 Chipped/Short Ram Intake/Flowmaster 40 series/Roof Rack/4 6in hellas facing forward/2 3in facing reverse/Linex'd cladding & bumpers/Cragar Soft 8's/31x10.50x15's/2.25 KOR BB/KOR Rad support/Black Diamond Shocks/All Metal Radiator/JKS Disco's
05 GMC Envoy XL. full Eclipse Components and 15in
drop down screen to replace stock unit....DD
84 Chevy K10 6inch sus. lift, 3inch body lift, 383 stroker, torsion posi, 3.73's.
97ZJMAN242 is offline
post #5 of 6 Old 02-10-2009, 01:21 AM
Colorado 5.9
The spring is in the bottom hose because there is suction down there. If there was no spring, the hose would collaps tight.
post #6 of 6 Old 02-10-2009, 07:11 AM
360limited
My 5.9 runs between 210 - 220. That is when the fan turns on and off. I am pretty sure that is normal... I hit a tree and wrecked my radiator. So i have a new rad. new hoses and stat(180).
Jeremiah
1998 5.9 Limited stock for now
360limited is offline
01 wj 4.0 overheating still!!! Nburns24 ZJ Grand Cherokee Forum 21 04-02-2009 12:35 PM
overheating dude979 ZJ Grand Cherokee Forum 7 03-20-2009 10:49 PM
Overheating ben98zj ZJ Grand Cherokee Forum 5 03-06-2009 03:05 PM
My wj is overheating. Forbidinworks ZJ Grand Cherokee Forum 5 03-02-2009 01:40 PM
Overheating JForestZ34 ZJ Grand Cherokee Forum 4 10-20-2005 06:31 PM
