98 ZJ 4.0 codes - JeepForum.com
post #1 of 4 Old 08-15-2009, 10:30 AM Thread Starter
skiebuster
98 ZJ 4.0 codes
Wanted to ask...
In my 98 ZJ
I have 2 codes that are coming up every now and again...
PO442 Evap system small leak
PO455 Evap system large leak
where do I begin looking for leaks in the evap system ? How do i find them ?
skiebuster is offline
post #2 of 4 Old 08-15-2009, 05:19 PM
ZeeJay1997
There are some rubber splices in the line going back to the tank that rot after a while. One is under the washer fluid reservoir and another down underneath by the tranny, and one more on towards the tank.
Then there's the possibility of a bad gas cap.
If you have California emmisions, that's another story.
ZeeJay1997 is offline
post #3 of 4 Old 08-16-2009, 06:11 AM Thread Starter
skiebuster
Thanks ZeeJay! I dont think its the gas cap. I will crawl underneath and check the lings going back and see if i can find any of the splices dry rotted.
post #4 of 4 Old 12-01-2015, 03:36 PM
ayogeo
Just posted the same response on another thread. Check the rubber boots at the ends of your evap lines coming from your canister. Check your vapor canister, fuel leak detection pump, and your solenoid for any cracks or anything to be unplugged. I was just dealing with a similar issue in my 98 zj.
ayogeo is offline
99 WJ AZC codes 14, 15, 25 luvmywj ZJ Grand Cherokee Forum 0 09-10-2009 10:04 PM
Fault Codes, DTC Diagnostic Trouble codes ETC. ef1992 ZJ Grand Cherokee Forum 4 07-16-2009 01:59 PM
2K WJ not running right with fuel inj codes & No ASD relay output voltage codes. HELP hillside250 ZJ Grand Cherokee Forum 0 04-06-2009 02:17 AM
TCM P0750...codes and more codes and the one speed tranny Mattt0305 WK Grand Cherokee & XK Commander Forum 3 11-01-2008 09:50 PM
6 Codes... New to codes and Tranny issues jakewalczak ZJ Grand Cherokee Forum 6 02-06-2008 07:32 PM
