98 XJ Dana 30 in a 94 ZJ? - Page 2 - JeepForum.com
post #16 of 25 Old 06-25-2013, 12:47 PM
SLOspeed
In other words, for a front axle: a HP axle is stronger driving forward. LP is stronger going in reverse.
SLOspeed is offline
post #17 of 25 Old 06-25-2013, 01:09 PM
riot1987
I am going to assume this holds true to any HP axle?
Build thread^^
riot1987 is offline
post #18 of 25 Old 06-25-2013, 03:59 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
any HP front axle, to my knowledge.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #19 of 25 Old 08-28-2013, 11:22 PM Thread Starter
ikidd
Followup on this, yes, it works. Downside is you have to change the axleshafts and knuckles to get the ABS sensor and ring.
ikidd is offline
post #20 of 25 Old 08-29-2013, 02:14 AM
Timo_90xj
Timo_90xj's Avatar
[quote=ikidd;15848622]Followup on this, yes, it works.
Downside is you have to change the axleshafts and knuckles to get the ABS sensor and ring.[/b]
Not necessarily.
A lot of XJs have ABS brakes too, and as far as I know a lot of the knuckles on '90 and up XJs are equipped with the threaded holes for the abs wheel speed sensors. Both of my '90XJ had the holes, so did the axle that came out of the '99 XJ that had no abs.
Of course, if the axle came out of an XJ that had no abs there won't be sensors or ABS shafts installed so in minimum you do need the shafts with the ABS tone rings, and remove sensors from old knuckles and bolt them in to the XJ axle.
***Under construction***
Timo_90xj is offline
post #21 of 25 Old 08-29-2013, 04:13 AM
newfieZJ
Isn't there a minimum lift required to run the HP for clearance ? 3" IIRC
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #22 of 25 Old 08-29-2013, 01:51 PM
Timo_90xj
Timo_90xj's Avatar
I run it on 1.75" with zero issues. I tried without any bumpstops and wasn't hitting anything; pinion yoke would've been a very close fit @ full bump without slightly modifying the driver's side downtube. Full articulation is not a problem, since when the drivers' side is tucked up and pass side drooping, pinion shifts away from the block.
That being said, @ stock height (or lifted with zero added bumpstopping) I wouldn't run a HP D30 without double checking on the exhaust/ pinion interference.
post #23 of 25 Old 08-29-2013, 06:32 PM
Technohead
Here's a better idea. Don't rebuild the D30 in your ZJ. Rebuild the HP D30 then swap it in. Done!
-Eric
Technohead is offline
post #24 of 25 Old 08-29-2013, 07:31 PM
shaban
I ran a HP D30 without a lift, had issues with tranny lines rubbing against driveshaft on bumps.
shaban is offline
post #25 of 25 Old 08-30-2013, 05:12 AM
Technohead
Easily fixed!
-Eric
