98 XJ Dana 30 in a 94 ZJ? - JeepForum.com
post #1 of 25 Old 06-23-2013, 11:11 AM Thread Starter
ikidd
I've read that the XJ Dana 30s were reverse cut / reverse rotation while the ZJ were not. But when I look at replacement ring gear/pinion sets, they show as compatible which I can't imagine would be the case if they were different rotation.
Am I able to swap an XJ Dana 30 in to my ZJ while I rebuild the old 30? I might have to swap over the driveshaft as I think my old one is the long pinion version.
ikidd is offline
post #2 of 25 Old 06-23-2013, 11:14 AM
WhiteOut
WhiteOut's Avatar
The HP D30 axles were reverse cut gears. Yes, you will be able to put the XJ axle in while your other one is being worked on, it will be a direct swap.
PS: Thank you for sending the extra police and the military, much appreciated.
WhiteOut is offline
post #3 of 25 Old 06-23-2013, 11:19 AM Thread Starter
ikidd
Thanks, Whiteout.
Not sure what you mean by the police, though.
ikidd is offline
post #4 of 25 Old 06-23-2013, 11:43 AM
riot1987
That xj D30 will swap. Make sure your gears match
Build thread^^
riot1987 is offline
post #5 of 25 Old 06-23-2013, 12:04 PM
Timo_90xj
Timo_90xj's Avatar
Also keep in mind the HP D30 gears are roughly 30% stronger than maching ratio gearset on a LP D30 - when going forward that is.
***Under construction***
Timo_90xj is offline
post #6 of 25 Old 06-23-2013, 12:09 PM
WhiteOut
WhiteOut's Avatar
Originally Posted by ikidd View Post
Thanks, Whiteout.
I'm in Calgary. EPS sent about 300 officers and vehicles, the military sent 1200+ and tons of equipment.
WhiteOut is offline
post #7 of 25 Old 06-23-2013, 12:12 PM
riot1987
What about reverse?
Build thread^^
riot1987 is offline
post #8 of 25 Old 06-23-2013, 12:39 PM Thread Starter
ikidd
Apparently we didn't send enough, I got pulled over and ticketed for not having my 13 registration sticker on my plate today.
ikidd is offline
post #9 of 25 Old 06-23-2013, 03:24 PM
Timo_90xj
Timo_90xj's Avatar
Originally Posted by riot1987 View Post
What about reverse?
LP is about that same 30% steonger in reverse compared to the HP in reverse. In other words, HP front axle R&P is most likely destroyed when doing silly stuff in reverse..
post #10 of 25 Old 06-23-2013, 05:24 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
What about reverse?
on a typical LP front axle, you are actually on the "coast" side of the gears under power which is the weaker side. HP you are on the drive side, so in forward you are on the proper side of the gears.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #11 of 25 Old 06-23-2013, 06:48 PM
dusterdude
Seems we went from a question about finding reverse cut gears to folks expounding on the virtues of an hp30
dusterdude is offline
post #12 of 25 Old 06-23-2013, 09:24 PM
riot1987
The op was answered wasn't it?
Build thread^^
riot1987 is offline
post #13 of 25 Old 06-24-2013, 07:42 PM
dusterdude
I dont think so
post #14 of 25 Old 06-24-2013, 08:05 PM Thread Starter
ikidd
I dont think so
I'm OP and I approve the original responses. They answered my question, and apparently the XJ axle is stronger than my ZJ original. Might stick with it.
ikidd is offline
post #15 of 25 Old 06-24-2013, 08:10 PM
dusterdude
