98 v8- 12v switched source - JeepForum.com
post #1 of 4 Old 05-13-2013, 03:32 PM Thread Starter
OldManTan
Hey Guys
Finishing up my e-fan swap and down to the last wire.
Need a 12v switch/ignition powered source to trigger my relay. Wondering if you guys have any ideas?
Passenger side of the engine bay area would be great. if not... running a wire through the firewall from my aftermarket head unit harness
thanks in advance
OldManTan is offline
post #2 of 4 Old 05-13-2013, 07:55 PM
96zedjay
Several options in the PDC under the hood next to battery.
96zedjay is offline
post #3 of 4 Old 05-13-2013, 08:02 PM
ZeeJay1997
Since you are in Cal, I suppose it has Cal emissions?
If not, the connector for the evap pump will be stowed near the purge solenoid. Orange wire is switched ignition.
ZeeJay1997 is offline
post #4 of 4 Old 05-13-2013, 09:04 PM
dnuccio
IIRC cigarette lighter plug only gets power when the ignition is on, could tap off that.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
