'98 transmission problems - JeepForum.com
post #1 of 5 Old 08-16-2006, 12:09 PM Thread Starter
gbt102
'98 GCLtd. 5.2 V8 - just got the evaporator core replaced and oil changed. Now, the transmission shifts at lower rpm and doesn't feel right when cruising on the highway - when I let go of the gas, the rpm drops down to about 1500 and it feels like something is holding the car back and keeping it from coasting (overdrive clutch maybe?). The steering wheel has also always shuddered at (and only at 55 mph - ???).
I thought maybe my transmission would act funny if they topped off my transmission fluid with the incorrect type, or they disconnected my battery to replace the evaporator core and reset the electronics that store information about the way I drive.
Any thoughts?
gbt102 is offline
post #2 of 5 Old 08-17-2006, 09:17 AM
sniper0423
architecture steals my $
sniper0423's Avatar
same thing on rpm drop
ive occasionally noticed the same drop on my 97 zj. mine feels like it was a manual transmission that you let off of the gas on. for the wobble, i had one at 47 and just had my tires balanced and that took care of it. try it if you bought your tires from some tires store, cause usually this is a freebie. let me know if you have any luck or find anything out about the rpm drop.
sniper0423 is offline
post #3 of 5 Old 08-18-2006, 09:23 AM Thread Starter
gbt102
Yeah, I've been thinking more about it, and I am wondering if there's something wrong with the torque converter and the transmission isn't coming out of lockup properly, or maybe it's my throttle positioning sensor...good idea about the tire balance - makes sense if I only feel it at a specific speed - thanks.
gbt102 is offline
post #4 of 5 Old 08-18-2006, 10:24 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
How hard is it slowing you down. It should slow you down to a point, but not too much.
I would ask the shop what fluid they used. If they used Dextron, kick them in the jimmy. Have them flush it out and fill with ATF +3 or better yet, +4.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #5 of 5 Old 08-24-2006, 08:11 PM
sniper0423
sniper0423's Avatar
hey woody...i just changed my tranny fluid and filter and it has fixed the hard shift and drop in rpm for the most part ...still happens if you drive like you have a feather for a gas pedal like i do on the highway...but i refilled w/+4 and it is working like a charm
Transmission problems. HELP! jmack549 WK Grand Cherokee & XK Commander Forum 9 10-30-2008 11:01 PM
transmission problems 01gt ZJ Grand Cherokee Forum 5 11-14-2007 05:47 AM
transmission problems jeepnurse ZJ Grand Cherokee Forum 7 08-28-2007 05:04 PM
Transmission problems dogbait ZJ Grand Cherokee Forum 1 06-05-2005 07:03 AM
Some transmission problems and then some BOOM ZJ Grand Cherokee Forum 16 04-02-2004 10:57 PM
