98 Laredo Electric Window only pulses 5mm at a time - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 98 Laredo Electric Window only pulses 5mm at a time
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker PurchaBds fox ipf 2.0 racing series shocks now available at rock
Unread 04-04-2009, 08:18 AM   #1
jimmyjeepboy
On my Laredo the electric has developed the following fault.
When the down button is activated the window moves down 5mm and stops.
I have to release the button and push again for another 5mm.
This is the same all the way down, and repeats the same trick all the way back up?
Have owned the Jeep for a few years.
Within the fuse panel there are a few "re-settable" fuses.
One of these has needed constant removing and replacing since owning the Jeep. i.e the front windows and door lock stops working so remove the fuse/breaker, re-insert and all is good for 1 day or 10 days, depends how the Jeep feels.
Hope someone can shed some light, it is the inching of the window that is frustrating
Thanks in advance Jeep peeps
jimmyjeepboy is offline   Reply With Quote
Unread 04-04-2009, 06:05 PM   #2
elmer_fud
sounds like the wiring or motor in the window is shorting out and kicking out the resettable fuse. when you release the swith the fuse resets and lets you lower the window again.
I would probably start with checking or replacing the window motor because I don't think the window would move at all if the wires were shorting out.
Brian
95 ZJ, 5.2 V8,160,000 miles
Colorado Jeep Club member Pi
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline   Reply With Quote
Unread 04-04-2009, 06:41 PM   #3
hike4it
Just buy a whole new window reulator you can find them on ebay fro 59.00 and make your life simple it will take about 1hour to install it and its a done deal
hike4it is offline   Reply With Quote
Unread 04-04-2009, 06:42 PM   #4
johnnycrash
could be your track is dirty and its causing to much resistance for the motor tripping the fuse. id check that before replacing anything.
johnnycrash is offline   Reply With Quote
