98 Laredo Build Thread "Yumekui" - Page 2 - JeepForum.com
post #16 of 31 Old 08-03-2013, 09:00 PM Thread Starter
CanaanTSA5
Originally Posted by Myusername1674 View Post
Looks like a good Jeep! I don't personally like the tan, but it might be okay. I think they do sell tan bedlining, or so I've heard.
Yeah, she's in good shape. I really want to paint the whole think matte tan like a humvee. But the cladding will do for now. Thanks for the tip!
1998 ZJ 4.0 Stock 225/75R15 General Grabber AT2
191,000mi
CanaanTSA5 is offline
post #17 of 31 Old 09-23-2013, 12:20 PM Thread Starter
CanaanTSA5
So recently my 98 has had a tough time starting. Not all the time, about 75% of the time. 25% of the time it starts right up perfectly; the other 75% of the time it cranks from anywhere from 4 to up to 18 times before it reluctantly starts. When it does finally start, it's a really rough start. Engine is very rough for a while. I've gotten in the habit of letting run for a minute or so after that and just restarting it. Always starts just fine the second time.
The other thing is that it's been acting very sluggish lately. Like I have a lack of power. It takes a lot more to get up a hill than it use to.
I am going to be cleaning the IAC tonight, as I haven't done that yet. I will be changing the oil next week as well when my Tune-Up kit comes in.
Any thoughts? I'm still learning here, so any input is appreciated.
191,000mi
post #18 of 31 Old 09-23-2013, 02:50 PM
chaZJones
sounds like fuel pump issue
96 ZJ 5.2L 156k
chaZJones is offline
post #19 of 31 Old 09-23-2013, 03:01 PM
bigchieftaco
2005 WK
My ZJ did something like that when it was going out. It would start hard every time. I replaced the plugs, wires, distributor cap, and rotor but still did it.
Replaced the fuel pump and starts perfect every time.
I'd check the fuel rail Schrader valve. Give the engine a couple cranks but don't start it. Push in the valve and see if there is any fuel in it. If its all air, your pump is probably out. That's how mine was anyway.
Otherwise, if you have a pressure gauge, it should read 38-45 psi on the rail if I remember correctly.
bigchieftaco is offline
post #20 of 31 Old 09-23-2013, 04:21 PM Thread Starter
CanaanTSA5
The pump is what I was thinking as well. I will try that an see how it goes. Thanks.
191,000mi
post #21 of 31 Old 09-23-2013, 10:00 PM Thread Starter
CanaanTSA5
So I cleaned the IAC, idles better. That bottom screw is a b**** to get to..
191,000mi
post #22 of 31 Old 09-26-2013, 03:32 PM
Myusername1674
Yeah it really is!
Finally got it started! Stupid battery!
Sent from my couch using JeepForum app
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #23 of 31 Old 09-26-2013, 09:46 PM Thread Starter
CanaanTSA5
Yeah it really is!
I'm glad that I am not the only one who thought so, lol. I was standing there going, "Why the f*** wouldn't they just tilt this thing 90 so that the screws are sides?". Oh well, done and done.
Got my Crown Tune-Up Kit in the mail today. Gonna do it up on Monday as a demonstration in Automotive Class for those students who have never really worked in a engine bay before.
As an oil change is a part of it, I had a question regarding oil. At what point should you start using High Mileage Oil? I'm at 173,705 miles.
191,000mi
post #24 of 31 Old 09-27-2013, 05:05 PM
Myusername1674
Yeah it really is!
Hahahaha i just noticed, somehow when i posted this comment the other day i must have thought i was in the 'whatd you do to your zj' thread! oops.
(in progress)
post #25 of 31 Old 09-27-2013, 11:51 PM
chaZJones
from what I understand the only difference in high mileage oil is an additive that causes seals to swell slightly to help prevent leaks. so it depends on if you have leaks or want to spend the extra money for it. I wouldnt
96 ZJ 5.2L 156k
post #26 of 31 Old 09-28-2013, 04:56 PM
dusterdude
100,000 miles ago
dusterdude is offline
post #27 of 31 Old 10-01-2013, 12:32 PM Thread Starter
CanaanTSA5
Going to attempt to find my vacuum leak tonight at school with the smoke machine we apparently have. As for oil, decided to go with High Mileage since I'm at 174k and steadily rising, and 5W-30 since it's winter here. I usually run 10W-30 in the summer like probably a lot of you do as well. I am desperately hoping to find this leak, because I am not a fan of having no heat through my dash in the winter...We will see what happens.
191,000mi
post #28 of 31 Old 10-01-2013, 09:10 PM Thread Starter
CanaanTSA5
So it turns out I have (had) two vacuum leaks. One was just a hose, I patched that one up so now the vents work again. The other is coming from the TB. That one will take some investigating.
191,000mi
post #29 of 31 Old 10-11-2013, 07:45 PM Thread Starter
CanaanTSA5
Replaced my Fuel Module today. Wasn't ridiculously complicated, but was a pain to do in the driveway. Jeep has the pep back in it's step again. Now I just need to address a new IAC and possible wheel bearings (And eventually new rocker panels)
191,000mi
post #30 of 31 Old 10-12-2013, 05:12 PM Thread Starter
CanaanTSA5
I was driving home from work today and check engine came on, so I stopped by Autozone to grab the code (P0455). Large leak detected in EVAP system.
I just replaced the fuel module yesterday, and a few things we not a prime experience on doing that. For one, the pipes from the gas cap to the hoses for the tank rusted out and ended up getting stuck in the hoses to the tank. Had to pull them out with pliers, about an inch of it was stuck in the hoses. When I put it all back together I just stuck the remaining good pipe back into the cleaned out hoses. I clamped them on as good as I could, but the clamps were pretty rusted too. Is that most likely the cause for the code? My EVAP hose coming from the tank?
The only other thing I can think of is that in order to get the gas out of the tank, I poured it out through the EVAP hose, not the gas hose from the tank. The gas hose was too wide to pour into my gas cans, and I did not have a funnel. Was that a bad thing to do...? -.-
Thoughts? I'm pretty low on cash, and I am due for inspection soon, so any idea are welcome..!
191,000mi
