98 JGC Laredo from one problem to the next - JeepForum.com
post #1 of 1 Old 04-27-2011, 09:28 PM Thread Starter
gfd732
I have a 98 JGC Laredo I6 4.0 recently I had a problem with not spark issues so I replaced the distributor, button, plugs, wires, coil pack, Distributor Pickup Assembly, Crankshaft sensor and after all that we finally get the jeep to give us a check engine light. we checked the code and it called for a new ASD relay. we changed it and it now sparks.
the new problem is now the jeep refuses to stay started. First started out with a miss after we put the ASD relay but now it will idle for a minute or 2 the shut down. i can get it to stay up a little bit longer if i lay the gas pedal on the floor. I found that it will die quicker if i turn the wheel or when it warms up. When it does shut down it is a violent shut down and sounds like engine just dropped out of the bottom of jeep.
I would appreciate and ideas anyone would have on this issue. I really like my jeep, however after today I am starting to second guess my loyalty to it.
gfd732 is offline
dying , idle , missing , spark , start problems
'05 G.C. Laredo Gear Problem kingstonjeep WK Grand Cherokee & XK Commander Forum 2 04-02-2010 06:35 PM
tranmission problem - Laredo kutluay WK Grand Cherokee & XK Commander Forum 4 08-19-2009 01:50 PM
HELP!!!!!! WG Laredo Problem junebubby ZJ Grand Cherokee Forum 4 09-29-2008 12:51 AM
98 GC Laredo sputtering problem slokum ZJ Grand Cherokee Forum 2 05-08-2008 08:26 AM
VIC problem in my 94 Laredo OH-ZJ-IO ZJ Grand Cherokee Forum 6 01-18-2006 08:46 AM
