98 JGC Driver Rear Cargo Window - JeepForum.com
post #1 of 8 Old 07-30-2011, 02:32 PM Thread Starter
Argo
Greetings,
I just got this Jeep a month ago (98 JGC Limited 5.2). I noticed then that there was what looked like silicone smudges around the rear driver's cargo window. I had assumed it had leaked at some point and was sealed. The window felt as solid in the frame as the passenger side. It has rained here quite good a few days a week since then. The window has never leaked.
Today, I was out doing some yard work and the window just didn't look right. When I looked at what it was, the window has slid down about half an inch and now gapping at the bottom. I pushed it back up into place but didn't seem quite right. So, I peeled it out of there. It looks like some type of white caulking was put in to hold with window.
I've searched online and this forum on this issue. I can't seem to find how this window is suppose to be in the frame. Near as I can tell, there is suppose to be a gasket on the inside of the molding that holds the window in. I can't tell but that might have been cut off say when it was removed at a junkyard. The molding on the inside has about a 3/16th lip that is fairly uniform with just a couple of scallops. So, I'm not sure if it is suppose to be like that or some part was cut off. There is also a clip with two half inch fingers and I notice three other locations where it looks like clips should go.
Should have taken some pics I suppose. I have it secured with gorilla tape for now.
How are these windows suppose to be attached? Is there a way I could glue it in?
Argo is offline
post #2 of 8 Old 08-01-2011, 07:00 AM Thread Starter
Argo
https://picasaweb.google.com/defriss...argoSideWindow
Not sure if the window just came unsealed at some point or was replaced, but some type of adhesive caulk was used to hold it in. Not sure why it didn't give out a week ago when it was 90. Now to scrape all that junk out and use the right stuff. I'm assuming I need something like black RTV.
Argo is offline
post #3 of 8 Old 08-01-2011, 07:17 AM
JeepOrvis97
JeepOrvis97's Avatar
Those windows are supposed to be glued in like windshields. Maybe you can buy the glue at autozone and I'd imagine you need the surface very clean.
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #4 of 8 Old 08-01-2011, 08:06 AM
JS97ZJ
It looks like someone called Rosie the Plumber instead of Safelite.
There is a windshield (rope type) caulking that's used for that kind of installation. The clips are only there to hold the window in place until the urethane sealant can fully set up. Usually 24 hrs.
You'll have to clean off all of Rosie's crap and prep the glass and frame with PVC cleaner or Acetone to get a good strong leak free bond. Hunt down clips so the glass won't try to travel. ( It probably won't bc that rope seal is very strong stuff)
Make sure you get it on correctly. There's no second chances with this stuff.
JS97ZJ is offline
post #5 of 8 Old 08-01-2011, 07:06 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
honestly, i'd just call a mobile glass repair company and have that fixed for 50$ instead of screwing around with it diy.
i hate windshields.
ratmonkey is offline
post #6 of 8 Old 08-02-2011, 11:35 PM Thread Starter
Argo
I have 2/3rds of the gunk removed. Looks like it is Liquid Nails! I'm going to clean it up the best I can. Then get a quote from Safelite and the local dealership. It might be cheaper and better than getting the materials to reinstall the glass myself.
Argo is offline
post #7 of 8 Old 08-02-2011, 11:47 PM
JS97ZJ
^^^x2 Just be sure to get all that junk off.
JS97ZJ is offline
post #8 of 8 Old 08-03-2011, 12:08 AM
scooter83
I agree, it looks like a total amateur repair job that someone did just so they could sell the jeep to you. Don't be surprised if you find other botched repair jobs.
Sometimes it's easier and better to just take it to the pros, and this is probably one of those situations. Like you said, the materials alone would cost a good portion of what it would to have the pros use their equipment.
You might want to call a few windshield places as their prices are very competitive (I have at least 20 places in my area).
scooter83 is offline
driver rear window not working? bigdadyzj ZJ Grand Cherokee Forum 7 10-31-2010 09:59 AM
HELP!!! Driver side window won't go up WBowie ZJ Grand Cherokee Forum 17 08-08-2009 01:57 PM
Driver-rear power window not rolling up Zaphod ZJ Grand Cherokee Forum 1 02-23-2007 09:00 PM
Driver Side Window.... CBlakeNS ZJ Grand Cherokee Forum 10 02-20-2006 05:33 PM
Broken Cargo Window jeepholic ZJ Grand Cherokee Forum 6 12-18-2004 02:43 PM
