98 Jeep Grand Cherokee Loredo 4WD - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 98 Jeep Grand Cherokee Loredo 4WD
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueRough Country Lift Kits and Parts!
Unread 04-21-2014, 05:42 PM   #1
2Bailey2
I have a whining noise while driving in 4WD. I have 2 questions. Is this usually expensive and if so what is the common problem? This Jeep has only 112,000 miles.
2Bailey2 is offline   Reply With Quote
Unread 04-21-2014, 06:03 PM   #2
79chiefs
1988 XJ Cherokee
Have you checked the fluid in the t-case?
79FSJ Cherokee Chief 350SBC_2x88 XJ Laredo I6-A 4wd_92XJ Laredo I6-A 4wd-SOLD
99WJ Laredo I6-A 2wd
79chiefs is offline   Reply With Quote
Unread 04-21-2014, 07:43 PM   #3
79chiefs
1988 XJ Cherokee
BTW this is the wrong forum.
MOD, could we get this moved? Thanks...
Unread 04-21-2014, 07:48 PM   #4
misfit77
Does whine all time?
At acceleration?
During deceleration?
I had my zj for over a year before getting rid if the mud terrains. Now I hear a whine at accell and cruising. I am sure there is nothing mechanically wrong.
misfit77 is offline   Reply With Quote
Unread 04-23-2014, 08:25 PM   #5
chris87xj
Jeepaholic
chris87xj's Avatar
1987 XJ Cherokee
I moved thid thread to the Grand Cherokee forum section where your fellow ZJ drivers can best assist.
Maybe you'll get lucky and it's just a worn u-joint in the front drive shaft.
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
COTY 2009
Vote for the Jurassic July Cherokee Of The Month!!!
chris87xj is offline   Reply With Quote
Unread 04-24-2014, 12:02 AM   #6
Oldfrog
4 wheel high, or 4 -lo?
4-lo will always whine....but I am assuming your are talking about 4 hi.
Does it seem to come from the rear of the vehicle?
All the time? Or just while under a load?
Cajun Recipes and Fishing tips
Words of wisdom, Posted by Zeejay:
"..it's not air, it is the opposite of air... suckage so to speak."
Stalling? Work through Zeejay's list
Oldfrog is offline   Reply With Quote
