98 Jeep Grand Cherokee fog light problems - JeepForum.com
post #1 of 13 Old 08-25-2005, 09:23 PM Thread Starter
bubba8008
Does anyone know where EXACTLY the fog light relay is located??
MY SITUATION:
I purchased some after market Xenon Bright White fog lights. I want to use my factory wiring so i can use the factory fog light switch inside my vehicle. I removed my factory fog lights, mounted my NEW fog lights, wired them to the factory fog light wiring harness....pressed the fog light switch On AND "NOTHING"... NO LIGHTS....... I tested the wires and I'm not getting any power so I figure it's a fuse. Come to find out it's not a fuse I need to look for but a relay...Right? WHERE is this relay?? Is there a # on it? Can i get a higher amp relay?? Any help would be appreciated. Thank You
Email me @
mgallardoiii@stx.rr.com
bubba8008 is offline
post #2 of 13 Old 08-26-2005, 12:54 AM
Colorado 5.9
Colorado 5.9's Avatar
LOL, I did the samething tonight trying to hook up a set of new driving/fog lights on my new to me Arb bumper. The samething happened except I had not tightened any of the nuts & bolts down on the bracket. The light worked just fine until I moved the light around a bit & it started sparking a bit. I just thought that since the metal braket was grounding & ungrounding causing the spark. Wrong! I tightened everything up & bamm! The fuse blew. Yes it is a fuse. There is a fuse & relay for the fogs. 15 amp & it's in the fuse box under the hood right behind the battery. It's a yellow one. It's dark now, but I think it's the upper right yellow 15 amp as your standing against the fender looking at the box. The relay is there too. It's "H" relay.
Now for the strange short. I made sure that the black wire (ground) from the stock plug went to the ground wire(black) of the(metal) body of the light & the blue wire(hot) whent to the white wire(hot)(lamp). It should not be any different than the stock setup but for some reason it is.
This is my theory: The differance between the new light & the stock light is that the bodies are different. THe new light is metal & the old factory light is plastic. THe body of the stock light NEVER grounds to the body of the jeep & the new metal one does. I think for some reason the metal body cuases a loop of some sort & that's the short. It does not make sence to me but tommorrow when I get some more fuses I'm going to NOT hook up the black wire frome the stock plug. Just the hot wire will be used. It will already be grounded by the metal to metal. Now I'm sure someone who knows more about these things could explain WHY this happened but I'm pretty sure of the cause. It also might be doing this because of the relay that's part of the circut. I don't have any experiance using relays so if I'm right then that's why.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #3 of 13 Old 08-26-2005, 04:52 PM Thread Starter
bubba8008
Fog Light Problem PERSISTS
I keep blowing my 15 amp yellow fuse. I tried a bigger 30 amp fuse and it still pops. Here's the kicker.....I disconnected both fog lights from the wiring harness, put in a new fuse, pushed the fog light button on & BAM the fuse blew!!! I was told that my fog light relay is "H" and it is under my hood. NO where under my hood do i see a relay with an "H" on it. What would it say?? FOG Relay??? I don't see anything like this....any ideas.....
post #4 of 13 Old 08-27-2005, 12:12 AM
Colorado 5.9
OK, I looked over my owners man. real good. The first pic is the diagram of the Power Disribution center( black box under hood). It says that H is open meening that there is NO relay there but 2 pages before this it says that the relay for the fog lights is H in the PDC. In the second photo of my box this is corect thogh that there is no "H" relay. NO H relay. In the fist photo on the lower right it says #6 is the fog light relay. Well, It's no relay. It's a fuse. Yes I was wrong last night when I said it's 15 amp. It's a 20 amp. In the photo is shows the new bright yellow #6 fuse sticking up. So, the only thing I can figure is from my book is there is no relay for the fogs. Just the fuse. As far as yours blowing with no fogs hooked up at all. It sounds like you have a( real) short somewhere. Mine does not do this. If I unplug the lights, the fuse stays fine. I still can figure it out. I tried what I said I would do last night by unpluging the ground wire to the fogs & nothing. It only works if the light brckets & light are isolated from the body of the jeep. Someone told me today that the power might be coming through the black wire insted of the blue wire causing the short when the light body is grounded. I will be checking this out next.
post #5 of 13 Old 08-27-2005, 12:30 AM
doyll
Glad the bumper worked out for you, Colorado 5.9. I had to back out of buying it when family problems came up literally over night.... and I was getting real sick of that dog of your too!!
1997 ZJ 4.0, 42re, 242, 3.73, tow hooks, reciever hitch, skids, OBA, F>R lift, Rancho 9000s, Addco 1.25", JKS discos, 265/75r MTs on stock wheels, 99+ intake, Banks look-alike header, sliders,
NEED: adjustable upper front control arms, front track bar frame bracket for JKS/RE bar, adjustable rear track bar, Addco rear sway bar, winch
doyll is offline
post #6 of 13 Old 08-27-2005, 12:59 AM
Colorado 5.9
LOL, Thanks! I still need to change my Avitar back over there. Hears 2 pics of the bumper all painted with the new lights. I just need to get them working now. I need to find some clear lenses to replace those damn amber lenses now too.
post #7 of 13 Old 08-27-2005, 12:59 AM Thread Starter
bubba8008
Thanks for your time and help Colorado 5.9. Looks like i'm gonna have to chase down this short in the wiring...will post up if i figure anything out.
post #8 of 13 Old 08-27-2005, 02:59 PM
Colorado 5.9
Update! I switched the wires. Blue(stock harness) to black & Black(stock harness) tp white. Everything works fine now. My friend was right. The black wire out of the stock harness is the hot wire & the blue is the ground.
Now I just have to wire up the big fogs.
post #9 of 13 Old 08-27-2005, 04:11 PM
anticrombie
anticrombie's Avatar
That is one SICK lookin zj colorado, that bumper really makes it stand out! Just wondering, but how are you hookin up the second set? Are you running a new set of wires and a new switch?
Charlie
anticrombie is offline
post #10 of 13 Old 08-27-2005, 05:26 PM
Colorado 5.9
Thanks! Yep, I just need to figure where to put the switch. I alread have a switch on the head light pannel. It's for the back lights that are in the TR. There is no more room there now. Since I have heated seats I can't put one on the oposit side. No room there either. I put the switch for the front locker in the center console under the lid.
post #11 of 13 Old 03-17-2015, 01:58 PM
FilthyCherokee
Colorado 5.9 how do I find a bumper like that that's the exact look I was looking for for my front end
FilthyCherokee is offline
post #12 of 13 Old 03-17-2015, 03:05 PM
SAR-Swimmer
You may have trouble getting an answer from him, as that's a 10 year old thread.
It's an ARB bumper, and if you type in ARB, you can find them on line, or most 4x4 shops could get them, but fairly expensive.
If you go into the stickies on the ZJ main page, under "Read before you post", you will find lots of choices for bumpers, (front and rear). Look for FAQs, then under miscellaneous , you'll find custom bumpers, ARB is the 1st one listed.
SAR-Swimmer is offline
post #13 of 13 Old 03-18-2015, 12:52 AM
FilthyCherokee
Oh snap lol I didn't even realize that but thanks
2000 Grand Jeep Cherokee Problems russb543 ZJ Grand Cherokee Forum 21 09-13-2009 11:05 AM
jeep grand cherokee 5.2 transmission problems dex1 ZJ Grand Cherokee Forum 3 11-29-2008 05:13 PM
Air vent problems on 97 Grand Jeep Cherokee david29 ZJ Grand Cherokee Forum 2 07-14-2008 03:15 PM
99 Jeep Grand Cherokee 4WD problems avdude ZJ Grand Cherokee Forum 3 12-04-2006 05:14 PM
Jeep Grand Cherokee Problems Chino31419 ZJ Grand Cherokee Forum 15 07-14-2006 10:56 PM
