98 Grand Cherokee Sputtering - JeepForum.com
post #1 of 12 Old 09-17-2010, 06:08 PM Thread Starter
kramer2105
After I start up my Grand Cherokee and let it run about 30 seconds, it will sputter for about 20 seconds and then run fine after that. The fuel pump was just replaced a couple weeks ago. Any suggestions as to what the problem is?
specs: 4.0L I6 all stock
kramer2105 is offline
post #2 of 12 Old 09-17-2010, 07:50 PM
coloradojeeper9
I just got my zj a few days ago and yesterday and today I had that same problem. I have no ideas
coloradojeeper9 is offline
post #3 of 12 Old 09-17-2010, 09:48 PM
jeffrayy
I have a 98 ZJ with the 4.0 doing the same thing. I think it is probably a sensor (cam shaft, O2, etc.) but I am not getting any codes when a diagnostic is run. I think the next step is to take out each sensor to check with a meter.
jeffrayy is offline
post #4 of 12 Old 09-23-2010, 02:31 AM
hellonwheels
sputtering
There are lots of voodoo fixes you can try, and you might even spend thousands of dollars like i did trying to fix this problem, but you will never fix it, so the only real fix is to put it on craigslist and sell it fast. Its a jeep thing lol
hellonwheels is offline
post #5 of 12 Old 09-23-2010, 04:20 AM
gothchick
Ummm... Maybe just do a basic tune-up instead of trying to pawn it off on someone else? Try cleaning the IAC and TB for idling issues and a tuneup for the rest.
gothchick is offline
post #6 of 12 Old 09-23-2010, 04:27 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Even if you check them all it could be an intermiitent failure, which is what it sounds like. Of all the miles of zj wiring that are 18=20 guage shorts are bound to happen. Just be patient you might be one of the luckty ones. If I wasn't spending money on the zj I'd be spending it on less important things like retirement,lol.
coralman is offline
post #7 of 12 Old 09-23-2010, 05:36 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
when was the last time you changed the wires? Ignition coil?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #8 of 12 Old 11-10-2012, 03:21 PM
PAFirefighter11
Quadratec Live Chat Rep
PAFirefighter11's Avatar
2015 JK Wrangler
Any resolutions from you guys? Just curious.
-Rick R
-2015 JKU - 3.5" JKS JSPEC Kontrol, 315/70R17" MTZ's, 17x9" Quadratec Rubicon Xtreme's, JCR bumpers & skids, JW Speaker tails, Dirty Dog netting/screens, Quadratec Auto Mirror Movers, etc
-03 VW Golf TDI - Diesel
-FDNY 9/11/01 - All gave some. Some gave all.
PAFirefighter11 is offline
post #9 of 12 Old 11-10-2012, 03:59 PM
hellonwheels
Yes I found a resolution, I sold it on craigslist for for $1500.00, that seems to be the only real fix
post #10 of 12 Old 11-12-2012, 02:40 PM
PAFirefighter11
2015 JK Wrangler
FWIW: When mine did this, I unplugged the upstream o2 and it ran perfectly after that!
-Rick R
post #11 of 12 Old 11-12-2012, 03:27 PM
cmax72ms
Idle air control
cmax72ms is offline
post #12 of 12 Old 11-12-2012, 11:01 PM
Oldfrog
2007 WK
Could be one of several issues. The main one being the PCM. Next time it starts and dies.....turn the key off, pop the hood and wiggle ( actually press them in towards the firewall seems to work best) on the computer connector plugs. If it starts and runs...then wiggle them again while it's idling. If it tries to stall, you need a PCM, or you could fix yours, or send it to Kolak here on the forum for repair. But under no circumstances should you buy one from either of the outfits in Florida. ( been there, done that). I bought a Cardone brand at Oreilly's and the problem was solved.
It could also be bad battery connections...not just at the battery, but at the fender ground, and where they enter the fuse box under the hood.
Another thing could be a bad CPS. Get a MOPAR brand. The rest suck.
Try the PCM wiggle test and get back to us before we tell you more.
And as for the guy who said it cant be fixed and sold his Jeep....he's wrong in saying it cant be fixed. We fix them all the time around here. It took me 6 months of denial before I swapped my first PCM. The 96-98 4.0s are the worst about PCM issues...but once they're fixed...they're fixed. ( until you need another PCM).
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
grand cherokee , inline 6 , sputtering
swapping a grand cherokee rearend for a cherokee dana 44 is it strait bolt in kojak70 ZJ Grand Cherokee Forum 2 11-01-2009 11:44 PM
98 Jeep Grand Cherokee 4.0L sputtering/losing power while driving corollatercel ZJ Grand Cherokee Forum 2 09-20-2009 03:48 PM
Trailer Hitch swap from Cherokee to Grand Cherokee hitchikerjoe ZJ Grand Cherokee Forum 4 09-29-2008 05:02 PM
1993 grand wagoneer/grand cherokee, alarm problem help! greenday1425 ZJ Grand Cherokee Forum 3 03-03-2007 11:16 AM
Grand Cherokee vs. Grand Wagoneer exhaust Wiley ZJ Grand Cherokee Forum 2 12-31-2005 07:15 PM
