98 Grand Cherokee Laredo - dome lights all flash while sitting or driving - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 98 Grand Cherokee Laredo - dome lights all flash while sitting or driving
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 04-02-2004, 09:25 AM   #1
ryan33
My 98 Grand Cherokee Laredo - dome lights all flash while sitting or driving. I have replaced all of the door pin switches and I thought the problem went away but it did not. The lights flash more when it is cold outside, mostly early morning. I was hoping to get some advice before I start replacing expensive switches and relays. Has anyone experienced this problem and found a fix?
ryan33 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2004, 09:45 AM   #2
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Why dont you post this in the grand cherokee section? This is supposed to be for comments and suggestions about jeepforum.com
2000 Jeep XJ - Chopped / Locked
1997 Jeep XJ - Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Join the XJ Owners Club | Download the iMarn® iPhone App!
SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather!
Homepage | Jeepspace Group|Twitter!|Facebook
BeachinXJ is offline   Reply With Quote Quick reply to this message
Unread 05-02-2004, 03:47 PM   #3
schaaed1
Me too!!
Just bought a '98 GCL and while driving to town today saw the rear dome light come on and then go off a little while later. It did this a couple of times.
Have not torn into anything yet ... but would suspect a faulty switch in one of the doors. Did you solve your problem & if you did what was it???
Thanks,
Ed S
schaaed1 is offline   Reply With Quote Quick reply to this message
Unread 05-02-2004, 08:31 PM   #4
Meerkat
I am assuming they don't flash at all without the engine running... which leads me to think it is vibration related. While you may have replaced all the door pin switches, have you checked to ensure all doors (including lift gate) are closing properly? I would disconnect each switch, and check for continuity when the door is closed. Try rattling each door to see if you lose continuity through the switch. Another tact you might consider, would be to disconnect all switches but one, see if the problem presents itself. if not, disconnect that switch and proceed to the next one, until it does. That will give you a starting point to start following wires back looking for shorts.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline   Reply With Quote Quick reply to this message
