98 Grand Cherokee Laredo - dome lights all flash - JeepForum.com
post #1 of 5 Old 04-02-2004, 09:04 AM Thread Starter
ryan33
My 98 Grand Cherokee Laredo - dome lights all flash while sitting or driving. I have replaced all of the door pin switches and I thought the problem went away but it did not. The lights flash more when it is cold outside, mostly early morning. I was hoping to get some advice before I start replacing expensive switches and relays. Has anyone experienced this problem and found a fix?
ryan33 is offline
post #2 of 5 Old 04-02-2004, 02:18 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
That is really strange.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 5 Old 04-02-2004, 04:19 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Maybe the ole Jeep needs an exorcism A faulty switch could cause this, but you replaced them?? Does it only happen in the rain? Could your rubber door seals be leaking to the switch?
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 5 Old 04-03-2004, 09:23 AM Thread Starter
ryan33
I live in Gilbert, Arizona and it doesn't rain much here. I know that it is not rain related but I guess it could be condensation.
ryan33 is offline
post #5 of 5 Old 04-03-2004, 02:09 PM
DrumBoy
DrumBoy's Avatar
Hi Ryan,
I was wondering if it was just your dome lights that flash or are things like your gauges as well? I was thinking it might be a ground problem or you might want to check your battery terms. for wear or connection. Maybe an alternator issue, do you have any aftermarket equipment installed? (i.e. CD Player, Amps,) Do you have any cold cranking or the like problems?
Just a thought.
DrumBoy
1998 Grand Cherokee Laredo I-6
K&N FIPK
Gibson GP400S Header
Kolak 2.5" exhaust system
Flowmaster 50
Bored TB w/Poweraid TBS
Optima Yellow Top Battery
Mean Green Alternator/Starter
DrumBoy is offline
99 grand cherokee laredo needs help. usafvet98 ZJ Grand Cherokee Forum 7 07-14-2009 02:21 AM
99 Grand Cherokee Laredo Robsho67 ZJ Grand Cherokee Forum 11 12-17-2008 08:34 PM
1996 Grand Cherokee dome lights intermittently flash on and off while driving cbrs85 ZJ Grand Cherokee Forum 5 11-27-2008 03:40 PM
06 Grand Cherokee Laredo gdubya WK Grand Cherokee & XK Commander Forum 8 03-02-2007 07:17 PM
98 Grand Cherokee Laredo - dome lights all flash while sitting or driving ryan33 ZJ Grand Cherokee Forum 3 05-02-2004 07:31 PM
