-   -   98 Grand Cherokee Laredo - dome lights all flash (http://www.jeepforum.com/forum/f13/98-grand-cherokee-laredo-dome-lights-all-flash-76694/)
ryan33 04-02-2004 09:04 AM
My 98 Grand Cherokee Laredo - dome lights all flash while sitting or driving. I have replaced all of the door pin switches and I thought the problem went away but it did not. The lights flash more when it is cold outside, mostly early morning. I was hoping to get some advice before I start replacing expensive switches and relays. Has anyone experienced this problem and found a fix?
Texas ZJ1 04-02-2004 02:18 PM
That is really strange.
Hunter
greasefingers 04-02-2004 04:19 PM
Maybe the ole Jeep needs an exorcism :D A faulty switch could cause this, but you replaced them?? Does it only happen in the rain? Could your rubber door seals be leaking to the switch?
ryan33 04-03-2004 09:23 AM
I live in Gilbert, Arizona and it doesn't rain much here. I know that it is not rain related but I guess it could be condensation.
DrumBoy 04-03-2004 02:09 PM
Hi Ryan,
I was wondering if it was just your dome lights that flash or are things like your gauges as well? I was thinking it might be a ground problem or you might want to check your battery terms. for wear or connection. Maybe an alternator issue, do you have any aftermarket equipment installed? (i.e. CD Player, Amps,) Do you have any cold cranking or the like problems?
Just a thought.
DrumBoy
1998 Grand Cherokee Laredo I-6
K&N FIPK
Gibson GP400S Header
Kolak 2.5" exhaust system
Flowmaster 50
Bored TB w/Poweraid TBS
Optima Yellow Top Battery
Mean Green Alternator/Starter
The time now is 12:49 PM.
