98 Grand Cherokee front end noise...??? - JeepForum.com
post #1 of 1 Old 08-28-2007, 07:03 PM Thread Starter
cocheesedod
I have a 98 grand cherokee 4.0L. I was having a popping noise coming from the front passenger side when I turned and slowed down that was accompanied by a loud whirring sound. The passenger side U-joint was bad so I replaced it a coulpe weeks ago which took care of the popping noise. This didn't take care of the whirring noise that sounds like a dry bearing or possibly a metal on metal rub. I ordered a new wheel hub and replaced it today but the noise is did not go away. I checked the oil in the front diff and it looked good. The only thing I noticed is with the front of the vehicle off the ground (in 2WD)I could spinn the wheel and the front drive shaft would also turn. If I am in 2WD should the front drive shaft be turning?? I know only enough to be dangerous when it comes to four wheel drives. I think the noise is coming from the front drive shaft but I can't pin point wether its from the diff or the transfer case. Any Ideas.......I am planning to take it out of town this weekend (around 500 miles) but I would hate to A$$ something up!!
cocheesedod is offline
99 Grand Cherokee noise when kicked down at 65-70 pinecrest2 ZJ Grand Cherokee Forum 0 02-12-2008 01:48 PM
Squeaky Noise in Front end on my 04 Grand Cherokee EricF07 ZJ Grand Cherokee Forum 2 12-15-2007 04:45 PM
Help! 99 Jeep Grand Cherokee Front End Whirring Noise a foley ZJ Grand Cherokee Forum 3 10-22-2005 01:27 PM
ZJ Grand cherokee Ltd noise... (s) slh542000 ZJ Grand Cherokee Forum 4 07-01-2004 10:30 AM
Rubbing Noise in Front-end when I hit bumps with my 1999 Jeep Grand Cherokee Laredo cjdietzman WJ Grand Cherokee Forum 9 02-21-2003 09:51 AM
