98 GC transmission shifting problem - Page 3 - JeepForum.com
post #31 of 45 Old 12-20-2011, 08:03 AM
ZickJagger
If the problem is the trans slipping in 1st but every other gear is strong...what would my options be??
ZickJagger is offline
post #32 of 45 Old 12-20-2011, 12:35 PM
jnicewan
Will it slip when shifted into Manual 1, or just drive 1st
jnicewan is offline
post #33 of 45 Old 12-21-2011, 09:42 AM Thread Starter
dpjag
Originally Posted by izackary View Post
Were the faulty conditions consistent with the gov sensor and solenoid? This one I drove seemed normal then off then ok again, then another random funny shift which seems more like a dirty sensor...
I narrowed mine down with a code scanner it have a manufacturer tranmission fault. But i think that the speed sensor will exhibit similiar symptoms as a faulty gov sensor and solenoid
dpjag is offline
post #34 of 45 Old 12-21-2011, 02:00 PM
PolkaPower
They don't always throw a code when they go bad. Mine threw the code then went away and then came back again. The Oreilly's code scanner gave me the fault codes.
PolkaPower is offline
post #35 of 45 Old 12-27-2011, 07:27 AM Thread Starter
dpjag
Mine transmission as been acting up again with it not wanting to shift all the time. But it is not only in first. I think i am going to replace the speed sensor tonight and see if that helps since it is a $20 item
dpjag is offline
post #36 of 45 Old 01-05-2012, 01:04 PM
JeepStangNCSU
1990 XJ Cherokee
I have a 98 ZJ Limited 5.2L with 178k that seems to slip between 2nd and 3rd when the tranny is cold. After about 2 runs from 0-45 MPH it shifts perfectly fine. Do you guys think this is a pressure sensor/solenoid problem or is my tranny going out? I've changed the fluid and filter about 20k ago.
Justang
1990 XJ Cherokee Laredo 4.5" Lift and 31s
1998 ZJ Grand Cherokee Limited 5.2L Bone Stock
2002 WJ Grand Cherokee Limited 4.7L Bone Stock
JeepStangNCSU is offline
post #37 of 45 Old 01-05-2012, 01:07 PM
PolkaPower
It's hard to say. A rebuild is pretty expensive compared to adjusting the bands and replacing the sensors. I always like to start with the cheapest fix first.
post #38 of 45 Old 01-05-2012, 01:13 PM
JeepStangNCSU
1990 XJ Cherokee
Yeah I agree. I guess the first smart thing to do is get my code scanner out and see what it tells me.
Justang
post #39 of 45 Old 01-13-2012, 06:51 PM
Bolo913
My '98 Grand Cherokee 5.9 at times wants to up shift early at lower speeds than normal. Then at cruising speed 55 or 60 it will act like it's slipping, I notice the RPM's going up & down while this is happening. Any clues? Thanks
Bolo913 is offline
post #40 of 45 Old 01-16-2012, 01:23 PM
RIP50AK
My 98 ZJ 4.0 tranny started haveing a hard time shifting into 2nd when cold. I had it serviced and it seemed to work better. Now about a month later it wouldn't shift into high. It was about -17F this morning and I don't know if that is affecting the shifting. If it is the cold would it likely be the selenoid?
RIP50AK is offline
post #41 of 45 Old 01-17-2012, 08:02 AM Thread Starter
dpjag
Sounds like the lock-up on the tq converter is failing. Or could be a little low on fluid. I am not sure if you can unplug the converter to dissable the lock up or not. I have done it on a chryster car before. If it is shifting up to early it could be your kickdown needs adjusted.
dpjag is offline
post #42 of 45 Old 01-17-2012, 08:04 AM Thread Starter
dpjag
It could be... i am not sure. How many miles on your jeep? Cold weather does strange things.
dpjag is offline
post #43 of 45 Old 01-17-2012, 11:43 AM
PolkaPower
Try adjusting your TV cable. Not just the shift points but the housing adjustment. You could check your fluid and adjust your bands as well. See if any of that works. If none of that helps then start looking at the sensors.
post #44 of 45 Old 01-20-2012, 10:43 AM
1ATony
Vendor
1ATony's Avatar
My tranny slipped last night in 1st gear. I didn't let it warm up and left work It slipped in first and then after about a minute it shifted perfectly fine, and it shifts fine as long as I let it wark up for a minute when it's freezing out. I was thinking about having the tranny flushed in it, to get some fresh fluid in there.
SHOP HERE FOR AWESOME
1ATony is offline
post #45 of 45 Old 02-14-2012, 02:38 PM
Bolo913
Well I took it to a trans guy who drove it and said he couldn't get it to do what i described. Go figure, Isn't that how it works!!
I've already replaced speed sensors, he did mention possible tq convertor lock up. Getting ready to take a long trip in it & getting kind of leary,,,,,would you?
Bolo913 is offline
first gear , shifting problem , transmission
GC having problems shifting. Transmission Problem? WM6405 WK Grand Cherokee & XK Commander Forum 9 04-19-2011 08:28 PM
transmission shifting problem, help please! customzj73 ZJ Grand Cherokee Forum 6 04-02-2010 12:51 AM
Transmission shifting problem 1st to 2nd flachman ZJ Grand Cherokee Forum 16 08-29-2009 10:24 PM
Transmission Problem...shifting 1st to 2nd rpsully8 ZJ Grand Cherokee Forum 3 01-30-2007 09:35 PM
'96 GC Transmission Shifting Problem When Cold tthomas436 ZJ Grand Cherokee Forum 5 10-04-2004 09:20 AM
