98 GC transmission shifting problem - Page 2 - JeepForum.com
post #16 of 45 Old 11-30-2011, 06:07 AM
jimebeans
Originally Posted by Degra101 View Post
Damn thats a Fine *** Vid.
That right there should be stickyd !
^^^^ agreed
jimebeans is offline
post #17 of 45 Old 12-01-2011, 07:43 PM Thread Starter
dpjag
I scanned it and I am getting a P1756 code ... so it looks like I will be ordering a governor pressure solenoid and sensor
dpjag is offline
post #18 of 45 Old 12-01-2011, 08:38 PM
david4127
That's one of the best vids I've ever seen on you tube I was getting goner preside sensor codes but couldn't find any info on it
david4127 is offline
post #19 of 45 Old 12-01-2011, 08:56 PM
stakebody187
Doing mine this weekend after 3 months of shifting it manulaly
Sent from my
HOOAH
stakebody187 is offline
post #20 of 45 Old 12-08-2011, 05:56 AM Thread Starter
dpjag
UPDATE: Finally got my parts in yesterday (Governor solenoid and pressure sensor) and installed them, new filter and 5.5Qts of ATF4 and it is good to go. All fixed and shifting fine!
dpjag is offline
post #21 of 45 Old 12-09-2011, 12:09 PM
Degra101
Links on the cheapest you can find for the two sensors ?
Degra101 is offline
post #22 of 45 Old 12-09-2011, 12:54 PM
PolkaPower
Don't get cheap parts. It's much better to get OEM. I got mine from www.kolak@aol.com
With the sensors and gaskets expect to pay around 180.00 maybe a little more.
PolkaPower is offline
post #23 of 45 Old 12-12-2011, 05:41 AM Thread Starter
dpjag
i got mine from transmission parts usa
http://www.transmissionpartsusa.com/...rts_s/1569.htm
I was not about to pay $118 for just one sensor at the jeep dealer.
Paid around $50 per sensor, plus $12for gasket and filter and another $50 on ATF
dpjag is offline
post #24 of 45 Old 12-12-2011, 08:51 AM
melk
I'm really torn on whether to rebuild my 42re or just buy a brand new unit.
Think I'll keep looking for a trans shop that feels right. Last one didn't seem too interested really.
melk is offline
post #25 of 45 Old 12-12-2011, 11:51 AM
PolkaPower
I had a shop put metal shavings in the pan then call me over to take a look at it. Turns out that it was a hundred dollar sensor making it shift like crap and the shop wanted 3000 for a rebuild. I have a really hard time trusting any shop with trans work.
post #26 of 45 Old 12-19-2011, 02:01 PM Thread Starter
dpjag
Just curious what sensor did go bad?
dpjag is offline
post #27 of 45 Old 12-19-2011, 06:29 PM
izackary
I'm glad your transmission is working as it should! Could this issue also affect a 46RE? As Melk saw this morning, I am looking to pick up a 5.9L Limited soon that is shifting a little funny. The service history is unknown so I am trying to generate a list of parts to replace (ie: TPS) or upgrade (cooler) as well as flush the system...
izackary is offline
post #28 of 45 Old 12-19-2011, 09:54 PM
frankcougar
I bought a 5.9 that would only go in first and reverse. I was hoping that it was the governor pressure sensor/solenoid. It ended up being the transmission speed sensor. Even better because I didn't have to drop the pan. It shifts great now. So it could be a possibility with the 46RE.
1998 ZJ 5.9 Limited White 187,XXX miles
1998 ZJ 5.9 Limited Slate 148,XXX miles "Sucker Punch"
frankcougar is offline
post #29 of 45 Old 12-20-2011, 06:24 AM Thread Starter
dpjag
I seen the throttle position sensor sometimes causes a problem as well as the speed sensor on the transmission. But the governor press sensor and solenoid seem to be more prevelant
dpjag is offline
post #30 of 45 Old 12-20-2011, 07:02 AM
izackary
Were the faulty conditions consistent with the gov sensor and solenoid? This one I drove seemed normal then off then ok again, then another random funny shift which seems more like a dirty sensor...
izackary is offline
first gear , shifting problem , transmission
GC having problems shifting. Transmission Problem? WM6405 WK Grand Cherokee & XK Commander Forum 9 04-19-2011 07:28 PM
transmission shifting problem, help please! customzj73 ZJ Grand Cherokee Forum 6 04-01-2010 11:51 PM
Transmission shifting problem 1st to 2nd flachman ZJ Grand Cherokee Forum 16 08-29-2009 09:24 PM
Transmission Problem...shifting 1st to 2nd rpsully8 ZJ Grand Cherokee Forum 3 01-30-2007 08:35 PM
'96 GC Transmission Shifting Problem When Cold tthomas436 ZJ Grand Cherokee Forum 5 10-04-2004 08:20 AM
