98 GC strange whistling sound when accelerating - JeepForum.com
post #1 of 20 Old 12-18-2008, 06:27 AM Thread Starter
fletcher1268
I've looked through a ton of threads on here about strange noises, but I haven't found one with the issues I'm having. I have 98 GC 4x4 with 5.2, a 2" lift and 31" tires. It has 107K. I've owned it for about 2 months. When I'm in park I can accelerate and the engine sounds great. When I'm on the road and I accelerate, there is a tonal whistle that sounds like it is coming from the drivers side engine area. I've made several long distant trips and the sound always seems to go away when I'm not accelerating. Anyone have any ideas or experienced this problem before?
fletcher1268 is offline
post #2 of 20 Old 12-18-2008, 10:09 AM
wyattarnall
do you think it could be coming from the speaker? a short in your speaker wire can make that sound, but you would think it would happen even when in park too.
wyattarnall is offline
post #3 of 20 Old 12-18-2008, 10:11 AM
wsar10
2003 WJ
or rather a ground issue. (if you here it through the speakers)
or could be a tranny sound.
wsar10 is offline
post #4 of 20 Old 12-18-2008, 10:11 AM Thread Starter
fletcher1268
No, I've turned the stereo off and it's still makes the noise.
post #5 of 20 Old 12-18-2008, 10:15 AM
wyattarnall
does anyone own a jeep that doesn't make strange noises?
post #6 of 20 Old 12-18-2008, 10:17 AM Thread Starter
fletcher1268
I'm pretty sure this has something to do with the drive train as it only happens when I'm driving it.
post #7 of 20 Old 12-18-2008, 10:49 AM
WJChris
WJChris's Avatar
could be a bad carrier bearing
WJChris is offline
post #8 of 20 Old 12-18-2008, 12:04 PM Thread Starter
fletcher1268
I found this on a website. "A howl or whine during acceleration over a small or large speed range is usually caused by worn ring and pinion gears or improper gear set up."
post #9 of 20 Old 12-18-2008, 02:22 PM
jonnn313
ive got a 98 5.9, does the same thing, doesnt bother me that much, it only does it every once and a while, like from a stand still, 0-60, but i dont think it does it when im already in motion
jonnn313 is offline
post #10 of 20 Old 12-19-2008, 06:23 AM Thread Starter
fletcher1268
How long has it been doing this jonnn?
post #11 of 20 Old 12-19-2008, 06:27 AM
kc8ztw
mine started doing it when i put in a high flow air filter (K&N). its like air whistling through the intake or the air filter. the reason it might not be doing in in neutral is cause when your revving your engine in neutral it doesn't require that much gas/air to get it going but when your going down the road its taking in alot more air when you got your foot down.
also our 415 v10 ford in out motorhome does it after we put a K&N in that too.
kc8ztw is offline
post #12 of 20 Old 12-19-2008, 06:39 AM Thread Starter
fletcher1268
That makes sense. I have two K&N's on mine....I hope that's what it is. Didn't think about it not doing it when there wasn't a load on it.
post #13 of 20 Old 12-19-2008, 06:52 AM
Phil Gerard
Former Mod
Phil Gerard's Avatar
Try tightening down your carburetor. You may have moved it or loosened it when installing the K&N and air is getting in under it through a thin space casing a reed like whistling. Ask me how I know - I have a spacer under my carb and it wears out and whistles under acceleration until I replace it.
Good Luck!
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #14 of 20 Old 12-19-2008, 07:06 AM Thread Starter
fletcher1268
Thanks for all the suggestions. This last one makes me wonder if this is it. That's exactly what sound mine is making
post #15 of 20 Old 01-13-2009, 06:30 AM
jonnn313
its be doing it ever since i got it, like a month ago, and ive put 2000 mi on with no problem, but i think the tranny is going, so im gonna put some sealers and chage the fluids in it. any other advise to keep the transmission from giving out?
5.9 dead
5.2 dead
looking for a 5.2!
jonnn313 is offline
HELP! strange noise when accelerating cbas84 ZJ Grand Cherokee Forum 14 12-24-2009 04:58 PM
Whistling sound from my Cat nrdame ZJ Grand Cherokee Forum 0 10-02-2009 11:12 AM
Whistling noise from '08 Cherokee Laredo while accelerating and turning off. dyne WK Grand Cherokee & XK Commander Forum 4 07-20-2009 02:20 AM
WJ whistling sound EideWJ ZJ Grand Cherokee Forum 2 11-25-2008 01:31 AM
Wierd whistling sound stevegibbon ZJ Grand Cherokee Forum 4 04-20-2008 06:42 PM
