98 GC dieing - JeepForum.com
post #1 of 7 Old 11-26-2007, 05:20 PM Thread Starter
99grnjeep
99grnjeep's Avatar
98 GC dieing
My waggon runs great for about 3 days then the next it starts and dies. Changed the coil, Fuel pump, cleaned the IAC. any other idears.
No Road/ No Problem
99 wrangler,2005 liberty(the wife's ride)
Low out put 4 cylinder jeep club member #67
Green Jeep Club Member#200
99grnjeep is offline
post #2 of 7 Old 11-26-2007, 08:23 PM
Redbob
"Dying".........
Redbob is offline
post #3 of 7 Old 11-26-2007, 08:28 PM
indept
Originally Posted by Redbob
"Dying".........
Redbob,
wouldn't that mean it's changing colors on him?
99grnjeep,
Your "waggon" I hope you're not refering to your Jeep A waggon which is spelled "wagon" is red & says "Radio Flyer" on the sides.
Is your "Radio Flyer" giving any codes?
indept is offline
post #4 of 7 Old 11-27-2007, 04:19 AM Thread Starter
99grnjeep
99grnjeep's Avatar
No the jeep isn't giving any codes. And I'm sorry I can't spell like every body else on here. This use to be a very informative site. looks like a lot of smart***es, has moved in. I know this comment will probably get me baned but oh well.Also I didn't think people was supposed to flame other folks in the tec areas.
No Road/ No Problem
post #5 of 7 Old 11-27-2007, 06:25 AM
indept
I was just joking with you, Did you check your fule pressure. I know you have a new pump but there is a regulator mounted on the under body right above the rear that the pump pumps into. I have a 2000 4.0l and there is a fitting on the fuel rail to check pressure. You can buy a gauge for cheap at the local part stores.
indept is offline
post #6 of 7 Old 08-24-2011, 08:03 PM
greenzj96
check or replace crank position sensor. mine had the same problem
greenzj96 is offline
post #7 of 7 Old 08-24-2011, 08:22 PM
savannahzj
cps could be the culprit. get your meter and your manual and test it. If bad, replace with mopar not off brand as they are known to die quickly. I would verify steady fuel pressure as well. With your meter you can test all sensors/electrical components that are relevant. I just went through this, and believe me a meter and a manual saved me alot of time and money. My problem was the pcm. The pcm has its own ground, check that as well as the pcm plugs.
savannahzj is offline
Jeep keeps dieing thething ZJ Grand Cherokee Forum 4 02-03-2010 08:32 PM
Transmission dieing? tofuzeppelin ZJ Grand Cherokee Forum 6 04-04-2009 12:00 PM
GC keeps dieing on me idratherbfishin ZJ Grand Cherokee Forum 1 06-16-2007 02:32 PM
Intermittent dieing jmac46 ZJ Grand Cherokee Forum 4 04-09-2007 12:51 PM
Intermittent dieing jmac46 ZJ Grand Cherokee Forum 1 04-05-2007 08:15 AM
