98 GC AC evaporator replace? how hard - JeepForum.com
post #1 of 13 Old 05-25-2011, 11:46 AM Thread Starter
sdowney717
this does not have ATC.
sdowney717 is offline
post #2 of 13 Old 05-25-2011, 01:12 PM
MaintMech
Old and in the way
MaintMech's Avatar
You'll basically have to take the whole dash apart.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #3 of 13 Old 05-25-2011, 01:20 PM Thread Starter
sdowney717
do you mean remove the black rubber foam cover on top?
OR just whats underneath
post #4 of 13 Old 05-25-2011, 04:39 PM
PA 5.9
Uh, everything...
Not a job that requires much technical knowledge or skill, it just takes a long time.
PA 5.9 is offline
post #5 of 13 Old 05-25-2011, 04:47 PM
xJoshxx
2012 WK
Lots and lots of little baggies and plenty of No-doz
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #6 of 13 Old 05-25-2011, 06:20 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
There are some threads here as well as other jeep forums that will give you a better idea of the task. Do a search. There are some that are pretty detailed. It is a time consuming job and one of those you say ..."will this s*** ever end"? I would take and have the evap "sniffed" before I went that way. There are alot of other points you can dump gas.
coralman is offline
post #7 of 13 Old 05-26-2011, 08:19 AM Thread Starter
sdowney717
I have been looking everywhere for the leak and it is nowhere. The only clue pointing to evaporator I have is the scent in the air inside the jeep smells of r134-a.
you will notice it even if the engine is off and it sits, the interior air develops a goodly odor of pag and refrigerant. It takes about 3 weeks before it is all drained out of the system.
post #8 of 13 Old 05-26-2011, 10:04 AM
Kho5050
They have a florescent gas u can charge it with and after u run it take a black light and it will glow wherever it has leaked, that's what they do at the mechanics
Kho5050 is offline
post #9 of 13 Old 05-26-2011, 10:06 AM
Kho5050
I'm just saying it's alot of work to replace the whole evaporated if it's just a hose end or split u know
Kho5050 is offline
post #10 of 13 Old 05-26-2011, 03:25 PM
coralman
coralman's Avatar
If its that strong in the cab you are prob on the right track. See how much a a/c shop would charge you just to snif the air duct, leave the system off before you go. If You know anyone that works on central heat and cool systems the sniffer they have will work as well. 134 is still a halide and will be detectable.
coralman is offline
post #11 of 13 Old 05-26-2011, 04:20 PM
Kho5050
I still fek
Kho5050 is offline
post #12 of 13 Old 05-26-2011, 04:22 PM
Kho5050
Originally Posted by Kho5050
I still fek
I still feel sketchy about the sniffers, I know there suppose to work just as well but u can get false readings from condensated areas if it touches them
Kho5050 is offline
post #13 of 13 Old 05-26-2011, 05:34 PM
coralman
coralman's Avatar
I use one at least once a month on heat pump evaporator coils and yes they will false read if gotten wet. But more times than not its dead on. If youhave that bad of aleak in the evap coil and sniff it at the duct after the system has been off, accumulated gas will set it off quick with just a short burst from the fan. Just want you to be sure. This job is kinda a pita.
coralman is offline
how hard is it to replace the steering box on a 93 ZJ? jeepunlimited ZJ Grand Cherokee Forum 7 04-06-2011 04:18 AM
How hard is it to replace cylinder head conor.davis ZJ Grand Cherokee Forum 3 10-21-2009 09:22 PM
How hard is it to replace hard brake lines in '01 WJ? Crewdude007 ZJ Grand Cherokee Forum 1 04-06-2009 08:56 AM
Should I replace evaporator core too?? jhelmick ZJ Grand Cherokee Forum 8 03-08-2008 08:26 AM
How hard to replace cat 7thStranger ZJ Grand Cherokee Forum 2 10-09-2005 03:17 PM
