98 GC 4.0 No Spark - JeepForum.com
post #1 of 10 Old 07-10-2012, 09:08 AM Thread Starter
FLSnake
98 GC 4.0 No Spark
I have a 98 Grand Cherokee 4.0 2WD, it would start and run for about 30 sec then sputter and die, if I kept it accererated manually at about 1200 RPM it would continue to run ok until i allowed it to idle and again it would sputter and die, sometimes continue sputtering after the key was off also.
Sometimes it would start right back up and other times it would crank and crank and eventually start.
I changed the crank sensor and it did the same thing.
Now it will only crank, no fire, I am getting good fuel pressure when I turn the key on and it continues good as i crank.
I am getting no spark at the plug wires and no spark from the coil wire.
I put a volt meter on the 2 wire connector that feeds the coil and when I turn the key on i get a 12 volt spike then it drops to zero, as i crank i get variable readings from about .10 to .23, no where close to even one volt.
Any thoughts would be appreciated.
FLSnake is offline
post #2 of 10 Old 07-10-2012, 10:50 AM Thread Starter
FLSnake
Just an update...
I took out the new Crank Sensor and put the old one back in and now it will start but still has same original issues, I must have cooked the new crank sensor.
FLSnake is offline
post #3 of 10 Old 07-10-2012, 10:52 AM
JustN11
Try checking the IAC
JustN11 is offline
post #4 of 10 Old 07-10-2012, 12:00 PM Thread Starter
FLSnake
Is there a procedure to check it?
FLSnake is offline
post #5 of 10 Old 07-10-2012, 12:14 PM
JustN11
Well, I've never had IAC problems (knock on wood) but I've heard that you can hear it work. You could try to listen for it. The IAC has a pair of solenoids that make a noise when working. You'll need a stethoscope to hear it though. You might try unscrewing the 4 bolts that hold it down 1/8" and see if that makes a difference as well. There are quite a few threads on here that talk about diagnosing IAC problems. I would search "Idle Air Controller" on here and see if one of those threads could give you a better understanding of how to diagnose it.
JustN11 is offline
post #6 of 10 Old 07-10-2012, 12:53 PM
melk
How old is your battery? It's surprising the wonky effects a weak battery will have on the behavior of the Jeep.
melk is offline
post #7 of 10 Old 07-11-2012, 04:30 AM Thread Starter
FLSnake
The battery is about 1 1/2 years old, I could have it tested.
FLSnake is offline
post #8 of 10 Old 07-11-2012, 05:53 AM
melk
A general note on Sensors, they seem not to like Bosch. BorgWarner (BWD) or NTK/NGK seem to work ok, or of course OEM/Mopar.
I would make sure to check and clean the IAC as well, since that will present problems with idle.
melk is offline
post #9 of 10 Old 07-15-2012, 05:26 AM Thread Starter
FLSnake
The new crank sensor I bought was a BWD, would the IAC cause the hard start also? Sometimes it cranks on and on before it will restart.
FLSnake is offline
post #10 of 10 Old 07-15-2012, 01:00 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Did you disconnect the battery when installing the sensor? Almost sounds like a bad coil driver. Any codes?
Originally Posted by HighLonesome
coralman is offline
no spark to spark plugs??? jeepgcnp ZJ Grand Cherokee Forum 4 11-27-2011 09:08 PM
spark @ coil, no spark @ plugs 94GC52 ZJ Grand Cherokee Forum 4 07-09-2009 06:17 PM
no spark Brian93YJ ZJ Grand Cherokee Forum 8 01-06-2008 11:20 AM
93 4.0 GC - No Spark Rockdaddy ZJ Grand Cherokee Forum 3 11-20-2007 07:46 PM
No spark? dcgoff ZJ Grand Cherokee Forum 4 05-27-2005 05:25 PM
