98 engine in a 95 - JeepForum.com
post #1 of 13 Old 09-23-2013, 04:44 PM Thread Starter
Nemisis623
1995 XJ Cherokee
98 engine in a 95
I have a 1995 grand cherokee with a 4.0. it's getting close to 300,000 miles and i've found a 1998 4.0 with low miles. was wondering if there would be any issues with swapping the engines? any problems with the computer or sensors? also what are some things i might want to check on the other engine... it's out of the jeep, looks nice, but i honestly don't know if it could have a major internal problem. Any help or suggestions would be appreciated.
Nemisis623 is offline
post #2 of 13 Old 09-23-2013, 06:45 PM
ZeeJay1997
I've never swapped one but have seen some discussions on it... and I stayed at the Holiday Inn
The older engines have OBD1 compatible sensors that will need to be swapped over to the newer engine. They have 2 coolant temp sensors, one on the head for the gauge and one on the thermo housing (i think). The newer ones have only one on the housing, so you'll need to drill and tap a hole in the same spot on the new head.
Maybe someone who has done it will come to offer better tips.
ZeeJay1997 is offline
post #3 of 13 Old 09-23-2013, 07:30 PM
xcaliber81
Why not just rebuild yours? or is $$ an issue? would be much easier. For the record mine has 301986 mi so I know where your coming from but mine runs like a top.
xcaliber81 is offline
post #4 of 13 Old 09-24-2013, 09:33 AM
JohnnyZJ
its a lot easier to swap a motor than rebuilt one. and alot less costly. a properly rebuilt motor is easily over 2k. a good running low k one can be had for 500$ or less. that should answer your question why you'd swap instead of rebuilt.
donno about you but i have a hard time dropping 2500$ on a rebuild in a rig worth 500$....................
as for your question to OP, yep its an easy swap. you have to change over all your sensors however. this in itself is not hard. you just have to undo the old ones from the old motor and put em on the new one. take a lot of pics as you take it off.
you are going to have one issue, and thats with the temperature guage. on the 98 there is only one sensor. your 95 uses two different sensors one to the computer and one to the guage. this sensor is located on teh back of the engine block.
if you want a temperature guage you need to plumb in a new/separate one for the 95 (and use the same sensor) i put the new/second sensor in the thermostat housing and the wire there. you'll see what i mean when you pull the motors. you'll have an extra sensor.
yes i've done it and yes it is doable. just a royal pain in the butt if you don't know what i'm talking about. lol good luck
07' JKUR rollin on 35s
JohnnyZJ is offline
post #5 of 13 Old 09-24-2013, 04:36 PM
xcaliber81
I suppose, I have been told my jeep is worth 2500$ though so rebuilding mine is a no brainer.
post #6 of 13 Old 10-01-2013, 03:51 PM
JohnnyZJ
tell them to buy it off you!!!!!
what would you say mine is worth?
JohnnyZJ is offline
post #7 of 13 Old 10-01-2013, 04:01 PM
chadcmb
$501
haha
come wheel with me in alaska!
chadcmb is offline
post #8 of 13 Old 10-01-2013, 05:15 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
That was too perfect!
Originally Posted by HighLonesome
coralman is offline
post #9 of 13 Old 10-01-2013, 05:19 PM
xcaliber81
Its not for sale.
post #10 of 13 Old 10-01-2013, 05:27 PM
xcaliber81
besides I never said id get 2500 I have just been told with all the work ive done to it that it was worth 2500, and honestly thats what id be asking if i was to sell it but i wont selling my jeep at this point would be like loosing a son/daughter lol.
post #11 of 13 Old 10-01-2013, 06:20 PM
JohnnyZJ
My jeeps always for sale . I've had it on kijiji for 6500 a month no bites. Such is life. Just saying amigo it's an old rig. Don't drop to much coin on it. You won't get it back in sale
JohnnyZJ is offline
post #12 of 13 Old 10-01-2013, 06:22 PM
JohnnyZJ
Originally Posted by chadcmb View Post
$501
haha
Way to far . Unless I win the lotto. Then I will load it up and go
JohnnyZJ is offline
post #13 of 13 Old 10-01-2013, 08:35 PM
xcaliber81
Too late lol. I never inquired about it it was just brought up but seriously though the next person to get my jeep will be the junkyard if I smash it up to the point where its not salvageable. I recently quit smoking mary jane so I have no problem soaking more $$ into it now even more so now I got a 20$ per hour job :-).
compatability , engine swap
