98 5.9 wants to stall or idle out - JeepForum.com
post #1 of 6 Old 06-16-2011, 11:58 AM Thread Starter
onyx
She wants to stall or idle out. Only in. When she is at operating temp. In drive. I let her sit for a month. She started doing this. Even with the foot on the petal she will try and choke out
onyx is offline
post #2 of 6 Old 06-16-2011, 01:29 PM
MrMrMr
I'm having the same problem with mine. It might be water in the gas tank/bad gas. It started when my brother put sh*t wawa midgrade gas in. Put some "heat" gas treatment in the tank. It help mine out from stalling but still a little bit of an idle problem. I just put another bottle in, we'll see how that works.
MrMrMr is offline
post #3 of 6 Old 06-16-2011, 04:20 PM
MrMrMr
Scratch that, still having that same problem. It starts right up when it's cold, but when it gets hot I can't change gears or turn the jeep off for a second with out it idling out and stalling.
MrMrMr is offline
post #4 of 6 Old 06-18-2011, 10:42 AM Thread Starter
onyx
its weird ya I tried new gas. I run 93 oct. If i let her run for 30 mins she wont do it anymore. until the next time she cools and warms back up. cold shes fine. Im thinking an o2 or a map sensor. It couldnt be an intake manifold leak or something right? I dont think it would be. But who knows
onyx is offline
post #5 of 6 Old 06-18-2011, 04:22 PM
MrMrMr
It's not vacuum leak, I know that for sure. I thinking maybe TPS.... Can anybody help us out?!?
MrMrMr is offline
post #6 of 6 Old 06-18-2011, 04:36 PM
RE2Master
Possible problem fix
I am having the same issue with my Jeep (96 GC limited) I can drive it for days with no issue then suddenly BAM it dies while driving at normal speeds and sometimes starts righ tback up other times takes a while. It feels like running out of gas at times, chugs hard while dying then either picks up perfect or dies. I read on 4 other websites about 2 screws holding the cover to the PCM causing the problem (the ones directly under 2 of the connectors). It stated backing them out some and trying, or replacing with a longer screw and not fully tightening it. On all sites this fixed the problem and only cost at most $.50 from Lowes. I also think the fuel filter could be clogged so I will also change that on mine as it has 147K on it and im a recent owner so who knows if it has ever been changed. I hope this helps all of us!
RE2Master is offline
'98 4.0 Stall/Idle/Hesitation Symptoms dmask0 ZJ Grand Cherokee Forum 4 11-17-2011 04:56 PM
Erratic idle, then stall and no restart...and gauges dead at key start position arch_zj ZJ Grand Cherokee Forum 1 02-12-2010 10:27 PM
93 GC V8 - Rev, then stall... jrcart ZJ Grand Cherokee Forum 1 08-21-2006 07:36 PM
Engine is surging at idle and wants to stall during braking smclarke ZJ Grand Cherokee Forum 1 11-05-2004 12:54 PM
93 Grand Cherokee Rough start, Idle problems, tries to stall dwills898 ZJ Grand Cherokee Forum 1 10-13-2003 02:11 AM
