98 5.9 trans issues - JeepForum.com
post #1 of 7 Old 11-17-2013, 04:41 PM Thread Starter
laredoFM212
98 5.9 trans issues
Hey guys and gals i just picked up a ninner and when i put it into reverse it makes a weird humming grinding noise it's hard to explain. and when i do put it into reverse it slowly rolls into R. and as for the forward hears it makes the same noise and once and a while if i give er it jumps out of gear and hit's the rev limiter. The jeep has no lights on once so ever
Could this be some where near or in the valve body?? my novice buds of mine thinks it could be the converter
laredoFM212 is offline
post #2 of 7 Old 11-17-2013, 04:45 PM
JasonStebbins
First thing : Check the fluid level on the dipstick while running warm in neutral. These transmissions are very picky.
If it's not the fluid level it sounds like something internally is worn. How many miles?
Poop
JasonStebbins is offline
post #3 of 7 Old 11-17-2013, 07:24 PM Thread Starter
laredoFM212
it looks really good and no burnt smell and yeah i know there anal i had 2 other ninners one i think blew every clutch disk possible lol smelt well toasted but this problem is new to me
post #4 of 7 Old 11-17-2013, 07:36 PM
JasonStebbins
Hmm. Usually I would say replace the common Governor Pressure Sensor and Solenoid but there's no engine light and you said you can actually hear it making noise it's probably more then a sensor.
Poop
post #5 of 7 Old 11-17-2013, 08:01 PM Thread Starter
laredoFM212
could be screwd up but no engine light. I just picked it up yesterday and looking it over it's deff never bin towed the middle of the hitch is really rotted lol but the rest is in super clean shape
post #6 of 7 Old 11-17-2013, 09:38 PM
JasonStebbins
Have you actually put a scanner on it and seen if any codes are stored? Worth a try before you start tearing the transmission apart.
Couldn't hurt to drop the pan and check the filter and magnet for debris/damage.
Poop
post #7 of 7 Old 11-17-2013, 10:53 PM Thread Starter
laredoFM212
well the noise is comming from the converter could that make it act like it jump out of gear when it fails
