98 5.2 Plenum Gasket Replacement - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 98 5.2 Plenum Gasket Replacement
Bead Lock Wheels! Raceline, Trail Ready, & Trail-GearBds fox ipf 2.0 racing series shocks now available at rockThe Original 3/8" Ruffstuff Diff Cover!
Unread Yesterday, 02:37 PM   #1
mudhawg93
Looks like my plenum gasket took a dump on me(not like I didn't see it coming), is it really worth it to spend the almost $200 on the hughes kit or am i better off just buying everything I need from my local parts store at the tune of about $61?
Does the hughes kit really THAT much to warrant the money spent?
98 ZJ Limited 5.2L Quadra-Trac Daily
89 MJ Pioneer 4.0L 4x4 Ranch Truck
93 Mustang LX 2.3L Project
mudhawg93 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 02:53 PM   #2
XJ93
That all depends on how long you want to keep the Jeep. The Hughes kit is an almost perfect solution to the problem. Using standard parts you will eventually have another gasket failure, it's a design flaw. Personally I'd love to just replace the entire intake with the Hughes intake and never have an issue again. But that's $600 my wife would not like me to spend.
XJ93 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 03:08 PM   #3
mudhawg93
Well I plan on keeping the jeep for a long time, I would love to do the full intake as well.
The only issue is the 4 day or so wait to get the stuff from hughes and then waiting for 2 days off together lol
Sent from my S5 somewhere in the woods
Unread Yesterday, 03:22 PM   #4
kg6mov
Hears the voices
kg6mov's Avatar
There are ebay vendors that sell plates just as good as the hughes one. Then just buy the good set of fel pro gaskets and you're set.
http://www.jeepforum.com/forum/f13/n...l#post23796778
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 03:55 PM   #5
jm8881
I recently got the hughes kit and replaced my plenum gasket and pan. The fact that it was an all in 1 solution was what sold me. All new gaskets, bolts, pan, everything needed to do the job without any trips to the parts store mid job.
jm8881 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 04:32 PM   #6
Snowfan2
Save your money. I manufactured and sold plates until I read something over at the Dodge forum. The plenum bolts installed at the factory are too long and bottom out into the manifold before providing correct clamping force on the plate/gasket. Here is a pic that shows the bolt, bottomed out, without the plate---torqued to spec. Note that the space is about the thickness of the plate.
[IMG][/IMG]
All that needs to be done to fix the problem is grind a bit of the unthreaded portion off the ends of the plate bolts. Wipe both plate and manifold gasket contact surface with alcohol after thoroughly cleaning and coat both sides of your new gasket with black rtv. Done. Forever.
Don't believe the ridiculous 'dissimilar metals' theory, which cannot be proven. Sink your plate bolts into your manifold without the plate and see for yourself.
Snowfan2 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 04:37 PM   #7
kg6mov
Hears the voices
kg6mov's Avatar
Interesting. I have read that mopar changed the gasket design for the later engines which is why the plenum failure is less common on newer magnums. Maybe they also changed the length of the bolts?
The dissimilar metals do still play a part, they will expand and contract differently and without proper clamping force they will blow out the gasket.
