98 4.0L getting the 99+ intake swap, vacuum routing? - JeepForum.com
post #1 of 9 Old 05-14-2009, 01:27 PM Thread Starter
MeWJWifeZJ
Who has done this conversion before? Should I use the old injectors and wiring or splice the newer stuff in? Also, where do the vacuum lines get re-routed to? The tees are not in the same spots and I am unfamiliar with the types of Vacuum the 4.0L puts out.
Praise to a Child is like Sunlight to Flowers
Traded away the WJ to get a commuter
We finally got another Jeep after 5 years without. Too bad it's ALL stock.
MeWJWifeZJ is offline
post #2 of 9 Old 05-15-2009, 03:49 PM Thread Starter
MeWJWifeZJ
btt, hoping to do the swap this weekend.
post #3 of 9 Old 05-15-2009, 06:53 PM
bucko132
im new to zj's what is the advantige of doing this?
bucko132 is offline
post #4 of 9 Old 06-01-2009, 08:15 AM Thread Starter
MeWJWifeZJ
20-35 HP increase, bump in torque, bump in MPG. The HP gain was documented in a thread on a dyno
post #5 of 9 Old 06-01-2009, 09:12 AM
squashman702
1994 ZJ
With supporting mods. The guy that gained this much over on Mallcrawlin had a pretty extensive build. It looks like 5 hp or so is expected if done without anything else.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #6 of 9 Old 06-01-2009, 09:27 PM
muddyjgc
2005 WK
I did the upgrade on mine about a year ago, here is a pic of the new setup.
The pic explains most of it. I plugged the two outer ports on the ends of the intake and used the center port for the vac line that runs to the purge solenoid, by turning the rubber elbows you can get that line to work.
I also had to extend the wires that go to the Intake air temp sensor since the 99+ intake has the sensor on the opposite side of the throttle body.
The bracket that holds the hard fuel line that runs under the intake wont work with the new intake without being modified. I haven't gotten around to modifying mine, the fuel line seems to be fine without it.
I used all my old injectors, fuel rail, brackets, Intake temp sensor,and
throttle body.
You won't see much difference in performance, just a little more low end ummph. I saw no mileage increase.
If you have any questions give me a shout.
On Edit: I just realized that this thread is 1/2 a month old. Did you get your intake installed?
muddyjgc is offline
post #7 of 9 Old 06-01-2009, 09:31 PM
elmer_fud
I would say use the same injectors. I wouldn't be surprised if jeep changed the fuel rail pressure when they went to the WJ
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #8 of 9 Old 06-01-2009, 11:50 PM
JrMechanic
To use the WJ Injectors you need an adjustable regulator like the Hesco one.
muddyjgc: How much low end did it give you? Anything at highway speeds? I've been debating on doing it to mine for awhile now, I can get the intake from a friend but I need a power steering pump and bracket from a 96+ (I have a 93) so it would cost me over $100 to do the mod. For what it would cost me, I figure I could put out a little more coin and just slap a cam in...
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #9 of 9 Old 06-02-2009, 08:52 PM
muddyjgc
2005 WK
Not a whole lot. Probably not over $100 worth of power. I seemed to have a little more pickup off the line. Mine only cost me $25 from pick-n-pull, and was a direct bolt-on.
The intake is supposed to be good for about 15 hp. Supposedly Jeep had to restrict the exhaust ports to make the 4.0 meet new emissions, at a cost of 15hp. So they redesigned the intake to flow better to get the hp back.
muddyjgc is offline
5.9 intake manifold vacuum lines Texas ZJ1 ZJ Grand Cherokee Forum 15 05-18-2009 09:24 PM
WJ->ZJ intake swap JrMechanic ZJ Grand Cherokee Forum 16 04-11-2009 01:09 AM
Vacuum hose routing pics/diagrams hmmhoyhoy ZJ Grand Cherokee Forum 0 11-16-2008 02:17 PM
air intake swap? legend6009 ZJ Grand Cherokee Forum 2 02-19-2007 06:38 PM
4.0l intake swap S_L_W ZJ Grand Cherokee Forum 9 11-25-2006 08:45 PM
