97 zj water pump replacement - JeepForum.com
post #1 of 5 Old 11-14-2013, 11:52 PM Thread Starter
bkarm
Need Halp! my brother brother bought a 97 ZJ 5.2L about 2 weeks ago and his water pump just went.. i have a '96 XJ and know nothing about ZJ's really.. anyone have any tips or how-to's for replacing the pump? thanks much
KCCO!
bkarm is offline
post #2 of 5 Old 11-15-2013, 12:42 AM
Oldfrog
2007 WK
If you cant get a field service manual quickly, I suggest using a Hayes manual for a water pump. It's pretty easy so Hayes is Ok for that job. Just make sure to get the gasket surfaces clean and dont gouge them with anything. Tighten the bolts in the order that the manual suggests to the proper torque. You'll be fine. Just take your time and buy the correct water pump. Might as well change the hoses and thermostat while you're at it.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 5 Old 11-15-2013, 04:43 AM
zj97ltd
Changing the little bypass hose should be considered a must when doing the water pump on a 5.2. It's not fun doing it later.
zj97ltd is offline
post #4 of 5 Old 11-15-2013, 05:30 AM Thread Starter
bkarm
no time to wait for a service manual... it is what it is tho wel make do with what we have. thanks much!
KCCO!
bkarm is offline
post #5 of 5 Old 11-15-2013, 05:10 PM
Eds97ZJ
Did this 2 months ago. Disconnect battery. Did not use manuals. Yes, make sure you clean surface good. I used paint stripper then scraped n sanded lightly with 80 grit then cleaned with brake cleaner spray. You have to remove alt A/C pump bracket to do it right. Yes, replace thermostat n bypass hose n any hoses that are suspect. I got my water pump from NAPA. The steel line that came with it was for Dodge. Luckily mine was in good shape so reused it. Make sure you get w/p bolts in right spots. Best way is to lay them out how you remove them or better yet put them back in old pump, same with Alt brakt. If your belt tensioner is old now's good time to replace that too. Let me know if you have questions.
1997 Jeep Grand Cherokee LMTD Loaded 5.2 V8 Q-Trac 4X4
Eds97ZJ is offline
