97 zj under hood bulb and socket - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 97 zj under hood bulb and socket
Iron Rock Offroad products - get them from Kolak!WIN a Rough Country Forged Track Bar - ExtremeTerrain!FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 11-05-2015, 07:24 AM   #1
jrobeson18
I dont know what happend to it. it was there yesterday but to day when i went out to the jeep to check vacuum lines and seal the antenna (ive got a leak in the jeep still) there wasnt a light on the hood anymore. it was dark out still when i got up. and everything is gone but the connector for the light. anyone know the part # or a replacment idea i can use. i have other lights to help see by but i like having everything thats supposed to be there. I thought about switching to an LED replacement.
jrobeson18 is online now   Reply With Quote Quick reply to this message
Unread 11-05-2015, 07:56 AM   #2
Uniblurb
Uniblurb's Avatar
We just had a discussion on the underhood lights and hope this helps.
http://www.jeepforum.com/forum/f13/u.../#post32576610
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
-Stalling ZJ? 12 things to check before replacing a sensor; the Dirty Dozen
-Crankshaft position sensor multimeter test. & video of testing.
Uniblurb is online now   Reply With Quote Quick reply to this message
Unread 11-05-2015, 11:02 AM   #3
XJ93
Grab one from a JY from any similar era Chrysler product. I pulled mine out and gave it to my cousin to use on his Dakota.
XJ93 is offline   Reply With Quote Quick reply to this message
Unread 11-05-2015, 11:36 AM   #4
armyRN
armyRN's Avatar
Can someone post a picture of what the factory light set-up looks like?
You can teach manners, but you can't teach class.
Trailer build: http://www.jeepforum.com/forum/f27/m...hread-1180456/
armyRN is online now   Reply With Quote Quick reply to this message
Unread 11-05-2015, 11:43 AM   #5
Uniblurb
Uniblurb's Avatar
Sounds like the cheapest route to go XJ93 but easier said than done. The junkyards have been removing the underhood/trunk lights for the past 8-10 years due to the policy of properly disposing of mercury switches.
Most states have this in place and here's the policy of removing/disposing of them in NC where the OP is located.
http://portal.ncdenr.org/web/wm/hw/p.../mercuryswitch
A little different than when I was a kid and our dentist gave us little bottles of mercury to take home to play with!
Unread 11-05-2015, 11:49 AM   #6
Uniblurb
Uniblurb's Avatar
Here's a photo of what my underhood light looks like on my 96 ZJ.
http://www.jeepforum.com/forum/f13/u.../#post11476450
I remember the one on my wife's 2000 TJ was a square box on the bottom of the hood with a lens on it.
Unread 11-05-2015, 11:55 AM   #7
XJ93
I did not know that. Here in Michigan you can find those lights under the hood of almost every car in the junkyard, including the green certified ones.
Unread 11-05-2015, 12:09 PM   #8
Uniblurb
Uniblurb's Avatar
Interesting and here's part of Michigan's policy.
http://www.michigan.gov/documents/d...e_383962_7.pdf
Wonder if they could be removing just the mercury switches or 'pill' from the lights? But you would think It would be a whole lot easier to just pull off the wire connector and pop the whole light assemble off.
Unread 11-05-2015, 12:49 PM   #9
XJ93
That's an interesting read Uni. I wonder if they are just pulling the "pill". It does seem like it would just be easier to take the whole fixture but maybe the people who pick up the mercury switches are telling them to separate them. Either way, if jrobeson finds someone parting a mid 90's Chrysler on CL that fixture would be easy enough to grab and shouldn't have any issue plugging it right in.
Unread 11-05-2015, 12:55 PM   #10
jrobeson18
Yeah, that would good to find a part out. Think i could find one with the mercury switch on ebay or anywhere else?
Unread 11-05-2015, 04:40 PM   #11
XJ93
With the way shipping regulations are it's hard to say. It'd be easier to find a Chrysler that someone is parting out or go to the dealer for one.
Unread 11-06-2015, 11:22 AM   #12
jrobeson18
Probably, is there a light i can splice in with out the mercury switch? I'm not familiar with those type of things.
Unread 11-06-2015, 11:32 AM   #13
GrtLksMarlin
http://www.michigan.gov/documents/de...e_383962_7.pdf.
Well that is very upsetting. They show a 68 Charger rear end yet a 69 Charger front end. What is the world coming to?
B.E.F.
GrtLksMarlin is offline   Reply With Quote Quick reply to this message
