97 zj sunroof needs help? - JeepForum.com
post #1 of 8 Old 04-25-2012, 06:19 PM Thread Starter
Bojeepus
ok its not in my profile be for you go looking there as i have 3 jeeps, my 97 zj orvis edd sun roof is having issues. It will open to vent and close but will not retract to full open. I have have a few switches for the sunroof that came with the jeep and tried one but no go. I can see the map lights dim when I open to vent. they don't dim like there is a load when I flip the switch to full open. Also i don't hear the motor even try to move is there a commen fix that i didn't find under the search?
Bojeepus is offline
post #2 of 8 Old 04-25-2012, 06:23 PM
booked101
my motor in my 97 orvis finally gave out and quit completely. Had to have the motor replaced, now it works like new in every direction.
good gas mileage is highly overrated.
(J)ust(E)mpty(E)very(P)ocket
booked101 is offline
post #3 of 8 Old 04-25-2012, 06:31 PM Thread Starter
Bojeepus
but would the motor having issues not effect the vent open and closeings
Bojeepus is offline
post #4 of 8 Old 04-25-2012, 06:36 PM
booked101
it did on mine. sometimes it would work and sometimes it wouldnt.
post #5 of 8 Old 04-25-2012, 06:40 PM Thread Starter
Bojeepus
hmm....see i have yet to have the vent not open and close its just the full open that dosen't want to work
Bojeepus is offline
post #6 of 8 Old 04-25-2012, 09:46 PM
sskilla
if you are feeling industrious pull your headliner and pull the motor out.
open the plastic box for its electronics and check the solder joints.
mine worked intermittenly for a while then i noticed the solder joints where cracked.
resoldered them and bam, good as new.
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline
post #7 of 8 Old 04-26-2012, 05:51 AM
ilive4cars0122
What he said ^ mine did the same thing as yours is doing. Those relays were bad and needed to be resoldered. They are in a little black box by the motor under the headliner.
ilive4cars0122 is offline
post #8 of 8 Old 04-26-2012, 08:19 AM Thread Starter
Bojeepus
thanks that just what i needed, some time next week then
Bojeepus is offline
sunroof , sunroof switch , zj
Need new sunroof LocalBlonde ZJ Grand Cherokee Forum 1 08-29-2011 08:03 PM
How to fix the sunroof. Newb1995jeepgc ZJ Grand Cherokee Forum 5 06-04-2011 10:25 PM
sunroof customzj73 ZJ Grand Cherokee Forum 0 05-14-2010 12:24 PM
Sunroof NEVADAGARY ZJ Grand Cherokee Forum 17 03-20-2009 12:21 PM
96 sunroof pic grandcher86 ZJ Grand Cherokee Forum 3 08-16-2004 06:06 PM
