97 ZJ seized in reverse. Then loud bang? - JeepForum.com
post #1 of 17 Old 01-31-2013, 09:24 AM Thread Starter
martymars
Put it reverse yesterday and it didn't want to go. Then a loud bang from the rear and then it went. After that it was fine. Any idea what could have caused that?
martymars is offline
post #2 of 17 Old 01-31-2013, 09:25 AM
Finallyajeep
something could have been frozen, as I see your from canada. Just a guess though
Firefighters Jeep Club
Finallyajeep is offline
post #3 of 17 Old 01-31-2013, 09:40 AM Thread Starter
martymars
Broke a record here yesterday. Not frozen..
post #4 of 17 Old 01-31-2013, 10:16 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
First... Like all new people. We have no idea what vehicle you have or what specifications it has. We need more information about your vehicle.
Year
Engine
Transfer case
Model/trim level
Anything done to it lately?
Fill in your jeep profile
ratmonkey is offline
post #5 of 17 Old 01-31-2013, 10:41 AM Thread Starter
martymars
It's a 97 JGC Laredo 4.0 all stock.
post #6 of 17 Old 01-31-2013, 10:56 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Define stock. There are several stock options for transfer case.
Being that you're driving it's probably the 249 case, and you probably broke the gears or an axle shaft in back. I wouldn't drive it till you verify everything is OK back there.
post #7 of 17 Old 01-31-2013, 12:15 PM
4Slow9erHybrid
the 4.0 Laredo's came with the 242 TC. It was probably stuck in 4PT. Let's hope nothing broke. Check the diffs as ratmonkey suggested.
1997 JGC Laredo 4.0 4x4 99900mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline
post #8 of 17 Old 01-31-2013, 12:35 PM
ElkhornRanch
I had my rear brake pads freeze down to my rotors once. It was during the winter, but I think it was rust or some kind of corrosion that stuck them down. They broke free with a bang and took the surface of the rotor with them. Quick and easy place to check.
ElkhornRanch is offline
post #9 of 17 Old 01-31-2013, 02:23 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
they could have either case.
post #10 of 17 Old 02-01-2013, 03:59 PM
wazntme
I had the exact same thing happen to me about a month ago, never did find the cause, checked both front and rear diffs, i was thinking it was a driveshaft u-joint that got caught that popped free, were you cut all the way left or right? i was...
wazntme is offline
post #11 of 17 Old 02-01-2013, 07:45 PM
dnuccio
249 was an option on all models, standard on V8s
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #12 of 17 Old 02-01-2013, 07:56 PM
newfieZJ
I don't think I have ever seen a Laredo with a 249/4.0 , limited yes . Now , I have seen it in WJ's , or at least pretty sure I did .
I'd say stuck between gears in the t-case but frozen back brakes wouldn't surprise me much .
Did you feel it go in gear , did the jeep kinda strain when you hit the gas ?? Maybe you're low on trans fluid , low enough and it would give a good jolt .
newfieZJ is offline
post #13 of 17 Old 02-01-2013, 08:46 PM
NashWheel
1994 ZJ
My 4.0 Laredo has a 231 TC stock. I too have had the same pop happen in reverse. only happened in the morning after really cold nights, happened about two or three times. never found the cause, but seemed to be frozen or something.
Lets Jeep!
NashWheel is offline
post #14 of 17 Old 02-01-2013, 09:11 PM Thread Starter
martymars
Well I brought it in to a friends shop and the guys had a look at it. I have a rear axle seal leaking and my parking brakes were in pieces. They said it might be low on differential fluid due to the leak. Nothing is broken though.
post #15 of 17 Old 02-02-2013, 10:37 AM
JS97ZJ
Submit you veh id # and get all of the info in order to fill out your profile for future threads. glad you found it was only the brakes and seal. http://www.jeep.com/wccsapp/universa...ull&category=U
JS97ZJ is offline
