97 ZJ interior lights flicker on and off!! - JeepForum.com
post #1 of 3 Old 08-16-2009, 05:41 PM Thread Starter
93 Cherokee
Has been this way for a while but I just pulled the fuse. Gonna try to "FIX" it finally. I pulled the overhead lighting console down. Everything seems to work fine with the door switches and stuff but then you can put it in drive and start to go and they will come on and stay on or flicker on and off. There are 2 plug ins inside the console. 1 goes to the computer portion and the other has 4 wires that run the lights (black, grey, pink, yellow). I have wiggled the connections and it doesn't seem to matter much. The wiring harness from the computer goes up inside the roof and then travels on. I have a multimeter so what can I do and test. Have heard it sounds like a bad ground but there is no ground connection that I see up there. The black wire on the harness I assume is the ground for the lights but like I said when I wiggle the harness it doesn't really affect it.
93 Cherokee is offline
post #2 of 3 Old 08-16-2009, 06:41 PM
kmk108
Is it just the two lights up front or all of the lights? If it's all the lights make sure that either all the doors are shutting completely or that the door switches are completely working.
30 BFG A/T, Flowmaster Super40, Alpine head unit, Alpine amp, Rockford speakers, Sony subs, cobra cb
White Jeep Club Member #108
2009 FA CUP CHAMPIONS
CAREFREE, WHEREVER WE MAY BE
WE ARE THE FAMOUS CFC
AND WE DON'T GIVE A F@#K
WHOEVER YOU MAY BE
CUZ WE ARE THE FAMOUS CFC
kmk108 is offline
post #3 of 3 Old 08-17-2009, 09:41 AM Thread Starter
93 Cherokee
All the lights. Well I think I fixed it. One of the doors I put some tape at the contact point and it quit. Wife said it did it a couple times when she drove it. (was doing it like crazy). I am gonna shim it out with a washer. Thx.
Dash lights flicker on and off. mikey83 ZJ Grand Cherokee Forum 19 08-24-2014 02:00 PM
Lights flicker JesseOR ZJ Grand Cherokee Forum 20 12-06-2009 09:28 AM
Interior light flicker on/off 72MARIO ZJ Grand Cherokee Forum 1 12-04-2007 12:47 PM
Dash lights flicker and go in and out luckyjeep ZJ Grand Cherokee Forum 11 11-21-2007 11:56 AM
Headlights intermittently flash & interior lights flicker (at same time) vngdh WJ Grand Cherokee Forum 5 07-16-2003 06:16 PM
