'97 ZJ a/c accumulator switch jumper - JeepForum.com
post #1 of 10 Old 06-05-2011, 08:15 AM Thread Starter
technophat
I thought this may be helpful to someone.
To bypass the accumulator switch and run the compressor at 100%, simply remove the disconnect from the accumulator, crimp two male elec connector guys on a short piece of wire, and insert. This bypasses the accumulator switch and runs the compressor without cycling. This can help to troubleshoot or stabilize pressure to fill a system too low on refrigerant for the compressor to engage aka short cycling.
Accumulator with compressor switch
Homemade Jumper
Jumper bypassing accumulator switch
1997 ZJ Laredo, 4.0, 42re trans, 242 T-case
1994 ZJ Laredo, 4.0, 42re trans, NP231 T-case
technophat is offline
post #2 of 10 Old 06-05-2011, 06:49 PM
MaintMech
Old and in the way
MaintMech's Avatar
Thanks, useful info!
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #3 of 10 Old 06-06-2011, 09:12 AM
classicmetalman
Thanks
Robert
93 Laredo 4.0
96 Limited 4.0
Originally Posted by murphydajeep View Post
I say you should still hit something just to let it know you mean business, or shake a hammer at it in a menacing fashion
classicmetalman is offline
post #4 of 10 Old 06-06-2011, 02:33 PM
tallears
I don't get it, why would you need to bypass the accumulator to put more refrig. into the system. I thought the accumulators only job was to store possible water vapor that sometimes gets into the system...
tallears is offline
post #5 of 10 Old 06-07-2011, 04:12 PM Thread Starter
technophat
If the a/c system is too low on refrigerant, the compressor will short-cycle (turn on and off every several seconds) or possibly not turn on at all. How exactly this works, I have no idea, but using the jumper to bypass the accumulator switch will run the compressor (the compressor clutch) at 100% so a reading can be made from the low side schrader valve.
post #6 of 10 Old 06-07-2011, 04:42 PM
tallears
ok thanks for the new info, i just got done replacing my a/c compressor, accumulator, a/c condenser, radiator, clutch fan, water pump(a few times) etc etc...And the air works pretty darn good for a 13 year old. Not great but very good.. The only parts I really will need to replace one day our the ones under the dash (help me out here I'm having a brain cramp, can't remember there names) anyway I have alldata for that..and I'm not looking forward to replacing them (under the dash and all, need to remove a lot of stuff), but I know thats the only way to bring the system back to like new, next time I have that clutch problem I'll give your trick a try, because I have no fear of such things...it's air on, or new car..so I choose to repair repair repair..
tallears is offline
post #7 of 10 Old 06-08-2011, 05:36 PM Thread Starter
technophat
...the evaporator should be the last part, and the most difficult to access. A small price to pay for ZJ bliss lol
post #8 of 10 Old 07-08-2011, 11:08 PM
StellaTheZJ
Just used this trick, and it didn't work, at first. Apparently, my clutch had become a bit sticky.
I did notice that when I jumpered the compressor clutch too, it would pull in a wee bit, but not nearly enough to drive the compressor. I poked it with a stick while the engine was running and it engaged right away, but it would not turn on again by itself.
Then I maced it with some spray lube, and it seems to be working OK. I hope that just using the recharged system will get it engaging reliably again.
So, point is, thanks for the tip about the accumulator bypass, it got me going again too!
StellaTheZJ is offline
post #9 of 10 Old 07-11-2011, 02:23 PM Thread Starter
technophat
Thanx for the feedback. Glad to help
post #10 of 10 Old 07-17-2013, 07:36 PM
Mad-Duke
Thanks!
Mad-Duke is offline
