97 ZJ build progress (so far) - Page 2 - JeepForum.com
post #16 of 23 Old 06-27-2013, 08:08 AM
ZJfreek
Zj's have frames?
96 Grand Cherokee 5.2 V8
ZJfreek is offline
post #17 of 23 Old 06-27-2013, 11:17 AM
riot1987
No^^ Unibodies.
Build thread^^
riot1987 is offline
post #18 of 23 Old 06-27-2013, 08:32 PM
ZJfreek
Originally Posted by riot1987 View Post
No^^ Unibodies.
I know they have unibodys the OP kepy saying mt ZJ's frame
ZJfreek is offline
post #19 of 23 Old 06-27-2013, 09:00 PM Thread Starter
ROFLwaffles
Don't be a smartass. You know what I mean. It just doesn't sound right if I say the recovery points are mounted directly to the unibody.
ROFLwaffles is offline
post #20 of 23 Old 09-11-2013, 08:40 PM Thread Starter
ROFLwaffles
Painted the interior trim pieces today. Got rid of that ugly faux wood.
Brakes come in next week. Up next, upgrading to slotted and drilled rotors.
post #21 of 23 Old 09-17-2013, 03:03 PM Thread Starter
ROFLwaffles
Brakes today. Flushed fluid, new heavy duty pads, new e-brake shoes, slotted and drilled rotors.
post #22 of 23 Old 10-11-2013, 07:15 PM
Shanebear
1994 ZJ
Love the mods. How did you do the grill? Looks great! My other question is how you cleared the corner lights. I'd like to do the same to mine
Shanebear is offline
post #23 of 23 Old 10-11-2013, 11:33 PM Thread Starter
ROFLwaffles
The corner lights were pretty easy. Just bought clear ones and put them in. lol.
The grill was a little more in depth.
1 First I took a wire cutter and snipped all the plastic innards out of all the grill openings and made sure they were smooth.
2 I used 600 grain sandpaper to rough up the chrome surface. Took a LOT of sanding.
3 Cleaned it off with mineral spirits.
4 Sprayed it with 3 coats Krylon Fusion satin black. About 1 hour between each coat. Let it dry overnight, then did 2 coats satin clear.
5 The inserts were gutter guard mesh from home depot. I cut squares about 1/2 inch larger that the backside of the holes in the grill opening.
6 Drilled a hole in the lip of the openings on each side. (top, bottom, left, right)
7 Used black zip ties to secure the mesh to the grill. Folded excess mesh over outside of the back of the openings.
8 Made 1 relief cut in 3rd opening from left to give room for hood latch.
VIOLA.
