97 ZJ build progress (so far) - JeepForum.com
post #1 of 23 Old 04-03-2013, 11:55 PM Thread Starter
ROFLwaffles
Started off stock....
Replaced plugs. Wires. Water pump. Serpintine belt.
Everything else seems fine so far.....
Made a custom grill
New wheels and tires. 15x7 235/75/15 Goodyear Duratracs
Cleared out corner lights
Painted the bumpers and cladding (removed front to paint)
Safari bar
Nerf bars
OVERALL PROGRESS SO FAR.
Next up.....
2" lift
White LED's for dash lights (go blue)
Smoke Altezza Taillights
ROFLwaffles is offline
post #2 of 23 Old 04-04-2013, 03:54 AM
gearheadnick
Nice job. You need some lights for that safari bar. I didn't put in any in mine for a while, but once I did it looked way better. (and I can see better at night since I have them activate with the high beams)
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #3 of 23 Old 04-04-2013, 04:15 AM
BlazerZJ
Where did you get the safari bar at?
1997 Jeep ZJ Laredo Prairie Pearl Coat, 4.0L, Selec-Trac NP 242, 3.5" RE Super-Flex Lift, Rustys Trac-Bar, JKS Quicker Discos, 15" Cragar Black "D" Windows, 31x10.5r15 Hankook Dynapro ATM tires,
BlazerZJ is offline
post #4 of 23 Old 04-04-2013, 05:31 AM
PolkaPower
lol I would not ever use those hooks on that safari bar, that is simply dangerous and you just lowered your ground clearance quite a bit with the side steps. Otherwise it looks nice.
PolkaPower is online now
post #5 of 23 Old 04-04-2013, 10:57 AM Thread Starter
ROFLwaffles
Got it at 4wheel parts.
post #6 of 23 Old 04-04-2013, 11:01 AM Thread Starter
ROFLwaffles
The tow hooks are not attached to the safari bar. Those are the stock tow hooks attached directly to the frame. They are just moved out with adjusters (pretty heavy duty ones too).
And yeah, I know I lowered my clearance. That's why my next step is going to be a lift.
Thanks though.
post #7 of 23 Old 04-04-2013, 01:22 PM
PolkaPower
I have never seen stock hooks stick out that far. How do the adjusters work?
post #8 of 23 Old 04-04-2013, 05:30 PM Thread Starter
ROFLwaffles
Well, the safari bar bracket mounts to the frame over the plate where the hooks are mounted, and covers where the hooks normally would be. The adjusters look like an "S' with straight ends. It moves them about 1" forward and about 1" outward from their stock placement through the bumper cover.
That way both the safari bar and tow hooks are mounted to the same area of the frame.
post #9 of 23 Old 04-04-2013, 06:01 PM
moparlover1992
Beautiful jeep man. I've always loved those purple ones. With the accent stuff you have done that thing is looking awesome. A lot like I'm doing with my white zj lol. Anyway, if you haven't ordered your lift yet shoot me a PM. Ive got 2.25" spacers with rubicon express shocks and front bumpstop extensions that I bought for mine before going to a 3.5 suspension lift. It's just taking up space so it's yours for cheap if you want it. Again tho, really nice jeep
moparlover1992 is offline
post #10 of 23 Old 06-26-2013, 10:06 PM Thread Starter
ROFLwaffles
Swapped the interior dash lights for blue LEDs...
post #11 of 23 Old 06-26-2013, 10:18 PM
riot1987
Does your dimmer switch still work or the LED's? Did you get a kit? I wanna do em all in the cab but want a COMPLETE kit to do it
Build thread^^
riot1987 is offline
post #12 of 23 Old 06-26-2013, 10:30 PM
ZJfreek
Bad *** I want the LEDs also, more info please.
96 Grand Cherokee 5.2 V8
ZJfreek is offline
post #13 of 23 Old 06-26-2013, 10:50 PM Thread Starter
ROFLwaffles
Dimmer switch still works just fine. Looks WAY better in real life. Picture washes out the colors a tad bit. There is no 1 complete kit to do it.
First off, I followed the directions in THIS thread.
http://www.jeepforum.com/forum/f197/...-98-zj-767865/
But, since I have a Laredo, the lights I needed were a bit different that the thread specified (For a Limited)
I also got my LEDs from 2 different sites.
6x these. 5 for dash, 1 for shifter.
http://www.vleds.com/bulb/194-168-15...21-1-pair.html
3x these for climate control (Laredo only) (easy to change)
https://www.superbrightleds.com/more...panel-led/709/
1 of these for key light.
https://www.superbrightleds.com/more...edge-base/226/
And 1x4mm and 2x3mm of these for wiper and headlight switches.
https://www.superbrightleds.com/more...panel-led/221/
Followed the instructions which were pretty easy, and viola.
post #14 of 23 Old 06-26-2013, 11:49 PM
moparlover1992
Awesome this is on my list of mods as well. Looks good. Making me itch to do mine lol
95 zj 5.2 np242 3.5'' IRO lift, IRO adjustable arms, KOR front trackbar, steering stabilizer and box brace, IRO rear adjustable trackbar, bilsteins, Hughes plenum plate, flow master 40, 31x10.5s on 15'' dc-2 rims
Mopar or no car!
post #15 of 23 Old 06-27-2013, 12:07 AM Thread Starter
ROFLwaffles
Only took about $40 worth of lights, and about 2 hours of my time to do. Simple, cheap, and easy.
