97 zj build - JeepForum.com
post #1 of 1 Old 03-14-2011, 11:11 PM Thread Starter
zjSAK
97 zj build
I am new to jeeps and have used this forum daily for the last month and a half. I am building a zj for dezert off-roading. I picked up the zj with 190000 miles on it was running ok but had some issues got it for 1500. I have used the form to cure the stalling issue by replacing the pcm plugs and hose clamping them works perfect and the jeep runs much better also was able to do a heater core but now have to it again because I did not check the blend door when I was in there. I just installed a 4.5 prem. IRO lift with adj. control arms and adj front and rear track bars did not do the tran. drop. Works great with very little vibration which I think mya be the tires if not will check the pinion angles. The people at IRO are first class answered my dumb questions and were very helpfull. I have 1.25 wheel spacers and 33 goodyears so I had to cut the front bumber and the rear fender I am also going to cut the rear as it hits when stuffed. I cant tell everyone how thankfull I am for this forum it has been great to read and see what can be done. I will post photos when I have enough post to do so.
zjSAK is offline
New ZJ Build W2001J ZJ Grand Cherokee Forum 13 06-01-2011 12:21 AM
Fbi (offroad build inspeter) build 93zjFBI ZJ Grand Cherokee Forum 8 12-18-2010 11:43 PM
Build up zj or xj? zjBRYCE ZJ Grand Cherokee Forum 11 03-17-2009 12:13 PM
where to buy 4.7 re-build kit??? kik_start ZJ Grand Cherokee Forum 5 04-29-2008 08:16 AM
what do i need to build my own kit? super13jew ZJ Grand Cherokee Forum 5 04-13-2008 08:56 AM
