97 zj brake line replacement - JeepForum.com
post #1 of 2 Old 05-11-2009, 06:35 PM Thread Starter
warrior23
I sprung a leak on the rear steel brake line on my 97 ZJ 5.2.I was gonna replace the main line from the front and both rear lines as all of them are rusted badly.My question is do I need to do anything special with the ABS system if I drain out the brake fluid.Or do I just bleed out the air thru the lines ?thnxs
warrior23 is offline
post #2 of 2 Old 05-11-2009, 09:26 PM
ZeeJay1997
Just bleed as normal. Just don't let you reservoir run dry or you'll need to bleed master cyl. It will gravity flow dry if you allow it to.
ZeeJay1997 is offline
Replacement Armored Brake Line wingless ZJ Grand Cherokee Forum 18 11-17-2013 06:19 AM
New calipers/brake line/pads, bled brakes, now i have no brake pressure! klwong1 ZJ Grand Cherokee Forum 13 11-16-2013 10:15 PM
Lowest steel line on frame rail, very rusty, brake line? ktmjeepguy ZJ Grand Cherokee Forum 12 10-08-2011 11:47 PM
Replacement Fuel Line QM2Rick ZJ Grand Cherokee Forum 3 08-17-2008 06:27 PM
transmission cooler line replacement jimbo2 ZJ Grand Cherokee Forum 2 05-02-2002 11:09 PM
