97 ZJ Belt Problem - JeepForum.com
post #1 of 5 Old 02-10-2013, 01:13 AM Thread Starter
ZJ5280
97 ZJ Belt Problem
Alright folks I cant find the problem on the ZJ. Stock 4.0 with the bad design (IMO) tension adjuster, long bolt through idler pulley. The belt keeps coming off and wedging itself behind the water pump pulley. I checked all alignment and all pulleys for wobble/loose etc. All seem OK. The part where I am stumped is it only happens when motor is shut off. I can fix it drive 1000 miles no problem then every third or fourth time the I shut it off it slips behind the water pump pulley. And only behind it stays put on everything else. What the heck!!!
ZJ5280 is offline
post #2 of 5 Old 02-10-2013, 01:42 AM
jnicewan
How does the belt look on the pulleys before it get thrown? Is it riding right on the edge of the w/p? Hating the tensioner design is ok, but if it was the design itself then a lot of us would be having this problem, you either have something bent, or out of line.
jnicewan is offline
post #3 of 5 Old 02-10-2013, 11:19 AM Thread Starter
ZJ5280
Like I said everything looks good when on everything, I will have to say the belt is a little to close to the back edge of the wp pulley. Visually everything runs good lined up and everything. It only slips off when I shut off the motor. Running will stay on all day long.
ZJ5280 is offline
post #4 of 5 Old 02-10-2013, 11:23 AM
Mark05059
take pictures... might try videoing it when shutting it off also
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 5 Old 02-10-2013, 04:32 PM
LouC
2007 WK
The problem is not the tension adjuster but most likely one of the pulleys is mis-aligned. Look at the vibration damper on the crank pulley, when they wear out the rubber piece fails and lets the part that the belt runs on slide in or out. Mine was starting to do something similar and it was definitely the vibration damper.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
