97 ZJ with 42RE cracked case, will WJ 42re work? - Page 2 - JeepForum.com
post #16 of 24 Old 10-30-2012, 07:40 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by NC_ZJames View Post
In the Dodge's, the PCM programming was different between between the two different styles, the values the sensor picked up are different and would also use the solenoids to control the pressures different. You could connect the plug on the transmission on an older truck, but would cause it to go into limp mode if it had the newer sensor/solenoid in it.
Searching for the 42re valve body, it comes up with only two different versions. One with the old style electronics and one with the new style, all internal parts are the same.
they have different springs, separator plates, and switch valves. any good shift kit for "all years" includes parts specifically for the different valve bodies. there were at least 3 revisions during the zj years.
ratmonkey is offline
post #17 of 24 Old 10-30-2012, 09:05 PM Thread Starter
azvinnie
1948 CJ2A
Thank you all. This is really great info.
So would a new trans case with the old valve body/sensor work? I haven't seen the inside of an electronic trans so I don't know if it's possible... last auto trans I rebuilt was a 727 in the early 80s.
unfortunately the 97 does not have a flashable ECM so it sounds like the other option would be some sort of aftermarket TCM (ie megashift. see http://www.msgpio.com/manuals/mshift/index.html for those that don't know what I'm talking about).
Thanks again. Great info!
azvinnie is offline
post #18 of 24 Old 10-30-2012, 11:01 PM
JrMechanic
If the valve body is the only difference in a WJ 42re, use the valve body from your current transmission after you've installed a Superior, Fairbanks, Transgo, or Sonnax shift kit. Problem solved.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #19 of 24 Old 10-31-2012, 03:52 AM
SpikeDude
I wonder if this could turn out to be a ultimate fix to the common 42RE's going bad? Would love to see if this works! Is it common for WJ 42REs to go bad like the ZJs? If not I kinda wonder why...
1999 Dodge Neon, SOHC, 5spd. Totaled
1997 Jeep Grand Cherokee Laredo, 4.0L, Selec-Trac, 30" BFGs. Cash for Clunkers :(
1993 VW GTI, SOHC, 5spd. Sold
2005 Dodge SRT-4, aka "POS", build in progress...
SpikeDude is offline
post #20 of 24 Old 10-31-2012, 06:06 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Yes, all year 42re's break in similar fashion. The later solenoid lasts a Little longer, but as he said, doesn't work with the earlier computers.
This line of thought won't do anything but spend your money on no improvement.
post #21 of 24 Old 10-31-2012, 08:30 AM
SpikeDude
Well darn...
I did find this awesome site in another thread that searches JY's near you for parts I found rebuilt trannys for $450!!! So... I might just get a spare tranny and keep it around in just in-case
post #22 of 24 Old 10-31-2012, 09:01 AM
BoostinChick
There is truth to a few comments in this thread. I have a 97 ZJ and the transmission was cracked. I picked up a 94 42RE and even then there were a few tweaks. The dipstick is on the opposite side, so had to come up with a makeshift bracket to bolt it to the block/housing. My only other concern would be how it bolts to the tcase, if its the same and the input shaft sizing.
Check Craigslist and local junkyards. A few near me have sales every now and again where you could pick up a trans for $100-200 and it comes with a 1-year warranty. I found my trans and NP231 tcase together for $200!
1998 Jeep Grand Cherokee 5.9L
BoostinChick is offline
post #23 of 24 Old 10-31-2012, 10:00 AM
LordHobbit
Well darn...
Do you mind posting that link here please?
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #24 of 24 Old 10-31-2012, 10:46 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Car-parts.com
Thought everyone knew that
42re , grand cherokee , stroker , wj , zj
