97 ZJ 4.0 Died and Will not restart - Not sure it's the CKP - JeepForum.com
post #1 of 14 Old 07-24-2013, 08:27 AM Thread Starter
merlot2twisty
Since the CKP is a PITA to change no matter how you look at it, I'd rather not "just change it" without being reasonably sure it's the cause.
DETAILS:
Wife was driving the ZJ yesterday in wet conditions. The rain had stopped, but we were getting local flash flooding -- so water intrusion is a possibility here.
Engine started sputtering and died over the course of about 5 seconds. After that, the engine would fire, run very very roughly for 2-5 seconds and die. Throttle input had no effect.
No Check engine light, no pending codes. As far as the PCM is concerned, nothing is wrong.
It gets fuel -- since it does fire a little -- you can also smell the raw fuel in the exhaust. So, this looks like an ignition issue to me.
I had read (somewhere) that when the CKP fails, you will get no fuel and no spark. Well, clearly, I am getting a little of both. Since the PCM shows no codes, I don't have a great starting point.
I had a screwdriver with me, so I pulled the distributor cap. It was dry in there. It looked like it was a bit worn down, but not enough to prevent it from running.
By the time I got home (on the tow truck) with the ZJ, the battery was dead from starting attempts. I put it on the charger and poked around a little bit, but go nowhere. Since it was getting late and the light was fading, I went inside to bed.
This morning, since the battery was fully charged, I cranked the engine over for at least 10 seconds, hoping that if a CKP code was going to show up, that it would. Still nothing. PCM is oblivious.
NEXT STEPS:
When I get home, I'm going to use my timing light to test for spark from the coil, and then on the output of the distributor. Since I know the injectors are firing (although maybe not at the right time) I know that I'm not having a fuel/injector issue.
I'd rather not just throw parts at a problem. Sometimes that's all you can do, but I'd prefer to exhaust the diagnostic tree first.
Could I have a bad cam sensor instead of a bad crank sensor? Possible coil failure? Distributor cap?
I found the ohmmeter test for the CKP; however, some people say that it can be bad and not show resistance -- so if I get resistance, it's definitely bad, and if not, it might be good -- and might not be.
What's the procedure to test the cam sensor?
Ideas?
We're going off-grid and moving to Texas! --
Check out our YouTube Channel! http://youtube.com/user/theratracelosers/
merlot2twisty is offline
post #2 of 14 Old 07-24-2013, 09:19 AM
JS97ZJ
Disconnect the o2's and see if the engine starts to run normally. Then check for water around your connections to everything else. (PCM)+
JS97ZJ is offline
post #3 of 14 Old 07-24-2013, 09:22 AM Thread Starter
merlot2twisty
Yeah, I just found ZeeJay's excellent troubleshooting post
http://www.jeepforum.com/forum/f13/1.../#post14045654
I will be testing the PCM wiring tonight.
post #4 of 14 Old 07-24-2013, 10:19 PM Thread Starter
merlot2twisty
Well, if this doesn't beat the band!
The ZJ was out of gas.
Apparently, our fuel gauge has decided to not work below 1/4 tank. I will be investigating more, but it's up and running now that I put some fuel in it.
post #5 of 14 Old 07-25-2013, 03:44 AM
Oldfrog
2007 WK
There was a recall on the 97 fuel sending unit. The symptoms were.....you guessed it....they showed 1/4 tank when empty.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #6 of 14 Old 07-25-2013, 05:50 AM
ZeeJay1997
http://www.youtube.com/watch?feature...&v=G-tCIRJH9p0
Go here and see if has had the recall performed.
ZeeJay1997 is offline
post #7 of 14 Old 07-25-2013, 07:51 AM
dellis
2005 WK
Welcome to the club.
dellis is offline
post #8 of 14 Old 07-25-2013, 01:16 PM Thread Starter
merlot2twisty
Zeejay,
Unfortunately, I replaced my fuel pump assembly last year with an AirTex unit -- so even if I was subject to the recall, they probably won't do anything for me.
Looks like I may be stuck with buying another pump assembly for $150+
Obviously, I will stay away from Airtex since it failed 4 months after the 1-year warranty expired.....Can just the fuel level sensor be replaced?
post #9 of 14 Old 07-25-2013, 01:23 PM
Oldfrog
2007 WK
yes
Oldfrog is offline
post #10 of 14 Old 07-25-2013, 01:41 PM Thread Starter
merlot2twisty
Where do I get the fuel level sensor? I've only found entire assemblies.
post #11 of 14 Old 07-25-2013, 01:43 PM
Oldfrog
2007 WK
Dealer
Oldfrog is offline
post #12 of 14 Old 07-25-2013, 01:45 PM Thread Starter
merlot2twisty
Lol. That's gonna be expensive.
post #13 of 14 Old 07-25-2013, 02:09 PM
Oldfrog
2007 WK
Ask about the recall. You might get lucky.
Oldfrog is offline
post #14 of 14 Old 07-25-2013, 02:12 PM Thread Starter
merlot2twisty
Fair enough. I'll check that link when I have my VIN handy
