97 grand cherokee Build help... - JeepForum.com
post #1 of 5 Old 06-19-2011, 03:56 PM Thread Starter
KillaJeep4569
2006 WK
Hey guys I am in the process of working on my jeep.
it is as you see in my sig
I have done Full Tune up, New Rear end, New disc brakes, rotors, pads, New tires, new Stinky rear shocks, air filter, New front Hub assemblies OEMs, front track bar, v8 tie rod upgrade,......
I would like to know what you guys recommend me start to rebuild replace etc...... It is a Surf Fishing Vechile in the spring, summer, fall, winter I snowboard. I am ruff on my truck as all my cars. (heavy Foot)
It has hit the 120k Mark, bought the truck last year at 105k, did 15k in 1year do alot of driving on beach.
The Muffler, n Cat Need replacing, Should I do the O2s also?
I need new LCA's front and rear lower/upper Which are more important?
Is the v8 Shock spring Mod Worth Doing?
I have a NV242 T-Case to install, How hard is it to do alone and how many hours?
Should I do the 2" Budget boost or go Bigger??? how pricey is this??
What other Mods does one Recommend for Beach driving and chasing Fish??
KillaJeep4569 is offline
post #2 of 5 Old 06-19-2011, 04:21 PM
melk
Really depends on how much $$ you want to throw at it.
Yes if you're going to replace the cat+muff you should replace the O2's as well. Either genuine Mopar sensors or NTK only, NOT Bosch.
You can upgrade your fuel injectors and grab a 99+ intake manifold as well. RockAuto has a header-style exhaust manifold for $180.
Lift depends on how big of a tire you ultimately want to run.
melk is offline
post #3 of 5 Old 06-19-2011, 08:37 PM Thread Starter
KillaJeep4569
2006 WK
So what do you mean upgrade injectors any more info would be great thank you
Um dont wanna throw toooo much, wanna get the essentails, make her a smooth ride again. and get all the slop out.
I got 255/75/16 and they rub my flaps and front nose
post #4 of 5 Old 06-20-2011, 10:41 AM
MaintMech
Old and in the way
MaintMech's Avatar
http://www.jeepforum.com/forum/f13/d...4-0-a-1145336/
Here's the lowdown on the injector upgrade.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #5 of 5 Old 06-20-2011, 07:33 PM Thread Starter
KillaJeep4569
2006 WK
Thank you very much any other upgrades to do?
Zj 93 grand cherokee 5.2l build ninjastar ZJ Grand Cherokee Forum 22 09-12-2011 11:42 PM
swapping a grand cherokee rearend for a cherokee dana 44 is it strait bolt in kojak70 ZJ Grand Cherokee Forum 2 11-01-2009 11:44 PM
2000 Grand Cherokee - Window Regulator & breaks/rotors. how to tell build date? rotogrip800 ZJ Grand Cherokee Forum 2 10-07-2009 12:54 PM
1993 grand wagoneer/grand cherokee, alarm problem help! greenday1425 ZJ Grand Cherokee Forum 3 03-03-2007 11:16 AM
Grand Cherokee vs. Grand Wagoneer exhaust Wiley ZJ Grand Cherokee Forum 2 12-31-2005 07:15 PM
