97 GC trailer hitch brake wiring - JeepForum.com
post #1 of 2 Old 05-19-2002, 08:10 PM Thread Starter
freddytran
Can someone outline the steps for wiring the trailer hitch brake light on my 97 GC? I just installed a new class III hitch and need to do the wiring. I've been told by many different people 2 different ways, one with the wiring harness kit and one with T connectors to the rear tail lights. Obviously I want to do it right and don't want to jack the electrical system! Thanx.
Freddy Tran
freddytran is offline
post #2 of 2 Old 05-23-2002, 01:13 PM
jmsjeep
You should get a kit and start the project when you have plenty of time to do it right. You will need to have a wire attached to you battery, so running the wire underneath the vehicle in a neat, safe way so it won't get caught on anything, takes a while. You will also need to ground everything. You should have an opening in the rear inside by the lights, you can put everything in there and punch a hole through the floor inside it. This way you won't cook your system on the dash.
I wonder were that dirt road goes?
'89 YJ 4 banger all stock, replacing all the worn out guts first, 97 grand cherokee limited
jmsjeep is offline
ZJ trailer hitch wiring maritimer ZJ Grand Cherokee Forum 1 05-20-2009 01:19 PM
GC trailer hitch wiring 97 hellrazor ZJ Grand Cherokee Forum 4 08-23-2006 08:29 PM
Trailer Hitch Wiring spichman510 ZJ Grand Cherokee Forum 1 04-24-2005 06:04 PM
Trailer Hitch Wiring spichman510 ZJ Grand Cherokee Forum 0 09-15-2004 07:37 PM
Trailer Hitch Wiring - 97 GC freddytran ZJ Grand Cherokee Forum 1 04-11-2002 06:50 PM
