97 5.2L water inlet tube...push in, o-ring type - Page 2 - JeepForum.com
post #16 of 17 Old 12-08-2011, 08:52 PM
housedl
Originally Posted by JrMechanic View Post
I don't understand why I hear of so many people having trouble with this tube. I've done tons and have never had one leak. Make sure there are no sharp edges on the water pump or the tube, install the O-ring dry, and smear a liberal amount of RTV over the end of the tube. Push the tube in straight with a back and forth twisting motion. If it won't go in all the way, place a screwdriver on the edge of the bracket and tap it the rest of the way in.
Originally Posted by Virmagicus View Post
Tranz shop has a **** ton of o-rings as well.
thanks guys... i found the actual part number and a picture of the complete thing.. i hope i can reuse mine.. mine is pretty rusty though...
having a hard time finding an aftermarket one though..
housedl is offline
post #17 of 17 Old 12-09-2011, 08:20 PM
MaintMech
Old and in the way
MaintMech's Avatar
A couple of good sources for O rings are: McMaster-Carr, and Grainger.
McMaster you'll have to buy online, Grainger has stores in some cities. Use the web.
Prices will blow auto parts stores away.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is online now
Write Up: High flow airbox mod with raised air inlet for water protection 5.2/5.9 rustynail ZJ Grand Cherokee Forum 22 03-30-2010 08:21 AM
muffler inlet and outlet diameters? on 05 WK? and inlet and outlet placement? PJNovinskee27 WK Grand Cherokee & XK Commander Forum 0 05-12-2009 07:01 PM
CCV HELP! Where's the manifold inlet???? TowMaster ZJ Grand Cherokee Forum 13 04-03-2009 08:37 PM
Water drip from tube near starter reznory ZJ Grand Cherokee Forum 2 01-06-2009 09:02 AM
Heater core return tube stuck in water pump SBlackfoot ZJ Grand Cherokee Forum 6 07-26-2008 08:30 PM
