97 5.2L water inlet tube...push in, o-ring type - JeepForum.com
post #1 of 17 Old 01-30-2011, 08:13 PM Thread Starter
kcult
Hi.
I searched a bit on here and found information about this pipe, but it seems most of the replacement pipes advertised and mentioned are ones that fit onto a nipple threaded into the water pump. The inlet pipe on my jeep has an o-ring on it and the pipe pushes into the water pump and that's it.
Well, today it sprang a leak. Neither parts house (that's open on Sunday) had the pipe or the o ring that fits onto it. I bought a small pack of assorted o-rings hoping one would fit. Well, several fit, but were too thick to allow the pipe back into the pump. I was seeing stars trying to get it back in. The o-ring that was thin enough to slip back in does not seal and now it leaks even worse.
Since the pipe is held steady by a bolt through the block, is it possible to just put some type of RTV sealer on it and go? I don't want to buy a new water pump just for that one o-ring.
Any other suggestions are definitely welcome.
kcult is offline
post #2 of 17 Old 01-30-2011, 08:18 PM
hiroku1324
Go to the dealer and lube the Oring with a little oil, should fit right in.
hiroku1324 is offline
post #3 of 17 Old 01-30-2011, 08:33 PM Thread Starter
kcult
Do you mean go to the dealer and ask for the o-ring?
kcult is offline
post #4 of 17 Old 01-30-2011, 09:19 PM
Coolcatracing
I used the oring that came with my new pump, cut it going on, got 2 new ones and cut both even soaked with oil. I spread some silicone all over the cut oring and shoved it in there and let it cure. Hasnt leaked yet after 8k miles.
08 Unlimited Rubicon 6 speed, 315/70-16 Kelly TSR, 1.5" Spidertrax spacers factory Moab's, Rubicon Express Flex arm 3.5" lift, Smittybilt XRC front bumper with D-rings, Body Armor Extreme rock slider steps, AEV snorkel, trimmed fender flares, Hella 8" HID driving lights
Coolcatracing is offline
post #5 of 17 Old 01-30-2011, 10:04 PM
jdk3034
all you should need is a new o ring a new water pump comes with a new o ring. it might be a metric o ring. try buying assortment pack from harbor freight or something and eye it up. if the pipe doesn't go in the pump by pushing it with your hand, tap the mounting bracket with a small hammer to get it in. i just did mine this weekend. i put the pipe in as far as i could push it, then put the other end in the heater hose and bolted the bracket down to the valve cover stud, then tapped it the rest of the way in with the hammer until the mounting bracket lined up with the hole in the accessory bracket.
jdk3034 is offline
post #6 of 17 Old 01-31-2011, 06:31 PM Thread Starter
kcult
Has anyone modified a new water pump to accept a threaded nipple?
kcult is offline
post #7 of 17 Old 01-31-2011, 08:29 PM
kachink
I did the same thing with mine when I replaced the pump. What worked for me was a 10mm ID x 14mm OD o-ring (2mm cross section). Clean everything well, put the o-ring on, then put RTV on it, insert it, and let it cure before refilling. Mine's been holding for about 4-5 months. It probably wouldn't hurt to try and put a slight countersink on the hole to keep it from shearing the o-ring, but make sure it's smooth so you don't nick it.
I don't think RTV on the outside after it's already leaking would work very well.
I think the threaded nipple is for a Dodge application of the 318. It would probably work ok to tap the hole for a nipple as long as there is sufficient wall thickness to support it. If it doesn't work you'll be replacing the water pump, so I'd try the new o-ring + RTV first.
kachink is offline
post #8 of 17 Old 01-31-2011, 08:31 PM
jdk3034
edit: do not tap bracket with hammer, mine is leaking. it seemed good at 1st, 2 days later it is leaking. i guess i will have to remove mine and replace with new o ring and lube it with wheel bearing grease, i used silicone spray only because bosch's water pump instructions said to use that and DO NOT USE grease for some reason about deterioration or something. i guess the silicone spray is not slippery enough to get it seated. i thought you always use grease, so bosch's instructions threw me off. now i gotta pull my fan and shroud and ac compressor off again, all because i listened to their dumb instructions instead of my own knowledge.
jdk3034 is offline
post #9 of 17 Old 01-31-2011, 10:41 PM
82JeepCJ7
1982 CJ7
Go buy a water pump, carefully remove the o-ring from the kit, and return the water pump.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #10 of 17 Old 02-02-2011, 07:57 PM Thread Starter
kcult
No one in the podunk town had the o-ring and very few even had anything too similar. I tore several trying to get the pipe in. I finally stopped at a tire store (that also sells lawn mowers, etc.) and went through their collection of o-rings. The closest thing I could find was just a tick small, so I got 2.
I put them both on and test fit the pipe. It went in with some resistance and when I pulled it back out, the o-rings were still intact. I smeared RTV red around the pipe and slid it back in. It sat for 24 hours and I fired it up. No leaking. I took for a spin around the block and parked it. No leaking. I checked it about 4 hours later. No leaking.
We'll see what tomorrow brings.
kcult is offline
post #11 of 17 Old 02-02-2011, 08:40 PM
Yardman Harry
O
Yardman Harry's Avatar
I had a heck of a time finding that ring. If you get the replacement tube (unfortunately the replacement tube is only for ram trucks) the o-ring will be on the tube.
I ran around town looking for o-rings to fit, checked advanced, pepboys, napa, and autozone. only autozone had the right ring. it was like 2 bucks
Yard
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #12 of 17 Old 12-07-2011, 05:21 PM
steveo12
does anybody know what size the bolt is or were i can find out for the water inlet tube the bolt that holds tube to block changed pump came up missing
steveo12 is offline
post #13 of 17 Old 12-08-2011, 02:33 PM
housedl
man getting ready to do this water pump thing and the inlet tube again... water pump that i replaced a few years ago died.. so i get to do this again.. going to buy new tube and all.. hopefully it goes in better... last time that stupid little o ring didnt settle right and the thing linked constantly.. sigh
housedl is offline
post #14 of 17 Old 12-08-2011, 03:51 PM
JrMechanic
I don't understand why I hear of so many people having trouble with this tube. I've done tons and have never had one leak. Make sure there are no sharp edges on the water pump or the tube, install the O-ring dry, and smear a liberal amount of RTV over the end of the tube. Push the tube in straight with a back and forth twisting motion. If it won't go in all the way, place a screwdriver on the edge of the bracket and tap it the rest of the way in.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #15 of 17 Old 12-08-2011, 06:55 PM
Virmagicus
Virmagicus's Avatar
Tranz shop has a **** ton of o-rings as well.
Jeff
Virmagicus is offline
Write Up: High flow airbox mod with raised air inlet for water protection 5.2/5.9 rustynail ZJ Grand Cherokee Forum 22 03-30-2010 08:21 AM
muffler inlet and outlet diameters? on 05 WK? and inlet and outlet placement? PJNovinskee27 WK Grand Cherokee & XK Commander Forum 0 05-12-2009 07:01 PM
CCV HELP! Where's the manifold inlet???? TowMaster ZJ Grand Cherokee Forum 13 04-03-2009 08:37 PM
Water drip from tube near starter reznory ZJ Grand Cherokee Forum 2 01-06-2009 09:02 AM
Heater core return tube stuck in water pump SBlackfoot ZJ Grand Cherokee Forum 6 07-26-2008 08:30 PM
