97 5.2L 0-60 times? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 97 5.2L 0-60 times?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 09-29-2003, 09:17 PM   #1
ModSport02
97 5.2L 0-60 times?
what is the 0-60 times on a 97 AWD 5.2L grand cherokee? and what HP parts will give the most perfromance for around $800?
I'm trying to make a sleeper out of my ZJ!!!
~UpCountry ZJ~
ModSport02 is offline   Reply With Quote
Unread 09-30-2003, 05:57 AM   #2
10achik
I ate what?
10achik's Avatar
I don't have my exact 0-60, but last week I ran the 1/4 in 13.9 @ 104 mph. My mod's are listed below, hope they help...
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline   Reply With Quote
Unread 09-30-2003, 08:01 AM   #3
jiggajeeps
I would suggest some sort of cold air intake (I prefer the K&N fipk2), a Mopar ECU, and a better exhaust. These mods are easy to do yourself, and seem to offer the most bang for your buck.
If you shop around and are patient, you could easily get all of this for about $800.
Current:
'98 TJ SE, stock
Past:
'04 KJ Sport, '98 5.9 Deep Slate, FIPK2, Mopar ECU, '93 XJ Country, '92 YJ 4.0 5speed
jiggajeeps is offline   Reply With Quote
Unread 09-30-2003, 01:47 PM   #4
pygocentrus
i think another good way is to but some weight, but i wouldnt.
get throttle body, air intake, headers, and chips.
pygocentrus is offline   Reply With Quote
Unread 10-01-2003, 04:59 PM   #5
iroc22
Ported cylinder heads, ported intake, bigger camshaft (I recommend comp cams they have a good lineup for the 5.2) 1.6 ratio rocker arms. Get a custom chip as well to be tuned to your mods. And then the usual headers and exhaust will be fine. Might want to upgrade the ignition system while you are at it to provide better spark. Maybe you could use the aftermarket supercharger for the 5.2 ZJ (cant remember the company I think it was Vortech). I believe it pushes only 9 lbs of boost and stock it will increase at least 80hp and 80tq.
2002 Jeep TJ Sport 4.0L Patriot Blue/Black Hardtop Dana 44
1996 Jeep ZJ Orvis fully loaded
1995 Pontiac Trans Am 5.7L - 6 speed
1928 Ford Model A - Street Rod Project
iroc22 is offline   Reply With Quote
Unread 10-01-2003, 05:30 PM   #6
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Email Kolak@aol.com. He is a engine and performance guru.
He sells headers, computers and other performance parts.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Unread 10-02-2003, 05:15 PM   #7
pygocentrus
is it safe to put a supercharger on a engine with almost 90000 miles?
Unread 10-02-2003, 10:58 PM   #8
iroc22
Yes.
Just make sure you have a higher flowing exhaust setup so the increased intake will be able to exhaust easier.
Unread 10-02-2003, 11:09 PM   #9
pygocentrus
hmm, ive been told by numerous people not to put a supercharger on my GC cause it has 90000 miles on it, they said i might destroy the engine. i really dunno what to do, i know if i ask the people at the store, theyll say anything to sell a supercharger.
Unread 10-03-2003, 11:32 AM   #10
iroc22
The main concern is the incoming increase in pressure may place a larger load on the piston rings and crankshaft bearings. 90k is nothing though for the 5.2 It's just starting it's life. Besides, I've seen chargers put on Ford/Dodges/Chevys with 100k+ miles on them. Like I said, make sure you make your exhaust system up to snuff.
Unread 10-06-2003, 11:05 AM   #11
5point9Limited
I suggest Intake...check out Ebay for cheaper homemade intakes that work the same as some that are $200-$300. I got one for $35 for my 5.9 ltd. Also a Cat-back from Flowmaster for sound and performance $350. I just ordered a Jet stage 2 chip from ebay...$125. Also Bosch Platinum +2 plugs $50. There is still room for a few other mods. Have fun!!
5point9Limited is offline   Reply With Quote
Unread 10-06-2003, 11:10 AM   #12
5point9Limited
To answer you question on 0-60 times, I believe they were hovering around 8 seconds flat to 60...not bad for a 4,000lb AWD off-roader!!
Unread 10-06-2003, 12:41 PM   #13
iroc22
Those Bosch Platinum +2 plugs are a gimmick. They are definitely not worth the money. The Jet stage 2 chip merely adjusts tranny TC lockup and spark advance. It's better to get a custom chip attuned to your mods, that way it will run properly.
Your best bet still is to stick to porting heads, intake and bigger camshaft. Factory castings are often poorly casted and have a decent amount of meat to improve airflow.
Check out this site below.
http://www.hughesengines.com/
Unread 10-06-2003, 03:26 PM   #14
5point9Limited
HELL, BOLT ON A SUPERCHARGER AND ADD THE NOS!! We are talkin budget here, right??
I agree with your mods...IF you plan to spend a couple thousand smackers. If I recall correctly, our friend stated that he wanted to spend $800. If you can't do the work at home, you have to pay someone. Most of us don't have the equipment or time to do these mods. Bosch makes a great plug especially platinum (single,+2,and+4). Jet stage 2 also adjusts the fuel curve, and yes there are better modules available, but Jet is no slouch. I think that the intake and exhaust combo gives the most bang for the buck. Anywho... I still have the fastest Jeep ever produced! YEE HAA!! Just playin I love ALL Jeeps the same!!
Unread 10-06-2003, 05:44 PM   #15
2k Limited
Heh, you might want to discuss that with i0achik. 13.9@104 might be tough to beat without a few more mods.
2k Limited is offline   Reply With Quote
