97 44RE delayed D or R - JeepForum.com
post #1 of 24 Old 03-05-2013, 09:03 AM Thread Starter
RamahX
I've searched high and low and cannot find my symptoms listed.
'97 ZJ Limited, 5.2, 170,000 well maintained.
Started having delayed initial engagement, only happens cold; goes into reverse easy, I back out of driveway, shift to Drive FROM reverse and delayed engagement. Have to rev engine then it catches. Once in D if I shift back to Reverse same thing, delay, then same delay back to D.
All other shifts are fine, OD fine. Will not repeat after driving at all. Only cold.
Changed fluid/filter and adjusted bands as per with dial indicator etc. Still same problem. Every search turns up slipping 1-2, OD slips, etc but cannot find anyone listing the delayed engagement R-D symptom.
Question, would a kit such as the Superior or Transgo kits solve this? Was hoping to get 200,000 before rebuild...
"Well, once again, we find that clowns and anarchy don't mix..." - The Tick
RamahX is offline
post #2 of 24 Old 03-05-2013, 10:17 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Low fluid level or bad governor and sensor usually do that.
ratmonkey is offline
post #3 of 24 Old 03-05-2013, 04:10 PM Thread Starter
RamahX
Not low fluid level, wasn't low before and isn't now. That leaves gov and sensor ..., and also wondering; the Superior kit has a 'rapid fill manual valve'...
RamahX is offline
post #4 of 24 Old 03-05-2013, 06:34 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
For full manual shift modification.
post #5 of 24 Old 03-23-2013, 12:27 PM
bob_351c
sorry to dig up an older thread but was the issue ever resolved? having same issue with a 46re exactly as described!
bob_351c is offline
post #6 of 24 Old 03-23-2013, 06:03 PM
RTLee
I had the same issues at one point after a recent rebuild. The gent that rebuilt the unit readjusted the bands and the issue was resolved.
I would have a trans shop (reputable) check it over.
RTLee is offline
post #7 of 24 Old 03-23-2013, 06:11 PM
bob_351c
Im liking the sounds of that. What were your symptoms? mine has recently started with a delay first thing in the morning between reverse and drive. And recently it also did it between park and reverse and then also reverse and drive. and after driving a few houses down everything is fine, shifts fine and switches between reverse and drive fine I have the pan off and it looks great inside, only a very fine layer of clutch material on the bottom of the pan, not even visible until i wiped it with a cloth.
bob_351c is offline
post #8 of 24 Old 03-23-2013, 06:16 PM
RTLee
That was the exact same symptoms. I'd pull the shifter and wait a few seconds for D or R to engage. Thinking "WTH! Just had this rebuilt!" The turns guy said it was pretty minor and only a simple adjustment to the bands. Sure enough, no issues since the adjustment was made.
RTLee is offline
post #9 of 24 Old 03-23-2013, 06:18 PM
bob_351c
did yours do it all the time or just the first take off of the morning?
bob_351c is offline
post #10 of 24 Old 03-23-2013, 06:48 PM
RTLee
Just on takeoff in the morning. Didn't do it right after the rebuild, but eventually showed and got worse until the adjustment was made.
RTLee is offline
post #11 of 24 Old 03-23-2013, 07:29 PM
riot1987
It could be a cracked case. I had similar issues in my old jeep after having the transmission rebuilt. When its cold the transmission is losing pressure through a small crack. When it heated up, the case expanded enough to seal the tiny crack and it was able to build pressure again. I dunno if its your problem but I had VERY similar issues and a new case is what it took to fix it.
Build thread^^
riot1987 is offline
post #12 of 24 Old 03-23-2013, 07:40 PM
RTLee
My case wasn't cracked, the bands were out of adjustment.
Cracked case should be obvious with a leak...
RTLee is offline
post #13 of 24 Old 03-23-2013, 07:47 PM
riot1987
Well dont I look foolish. I guess thats what happens when you scan a thread too leisurely. Mine wasnt leaking when I was having issues.
Build thread^^
riot1987 is offline
post #14 of 24 Old 03-23-2013, 08:43 PM
bob_351c
mine leaks but im pretty sure its from the neutral safety switch. Another thing i noticed is that ive had the pan off for hours and its still dripping, quite a bit. could this indicate a drain back issue? I would love that to be the problem but it still pauses in engagement after reversing and changing to drive. the reversing should have filled the torque converter, correct?
bob_351c is offline
post #15 of 24 Old 03-23-2013, 09:07 PM
riot1987
Oh boy.. Im not too much of a transmission guy. I just had some similar problems relating to the previous posts so I chimed in. Im not the best source on this one chief. Good luck though
Build thread^^
riot1987 is offline
