97 4.0 low power when towing - JeepForum.com
post #1 of 8 Old 09-24-2013, 09:54 AM Thread Starter
mobilehomer
I have a 1997 4.0 190,000 miles. New 'puter from advance, generic programming. When I tow my Tracker pro team 185, about 2000 lbs, it seems to not have as much power as it should have. Could it be that I need to go to a dealer to have the programming updated?
mobilehomer is offline
post #2 of 8 Old 09-24-2013, 10:43 AM
Oldfrog
2007 WK
You can check to see if your new pcm has CA emissions with a scanner. That might do it. New plugs and a general tune up may help.....or maybe your cat is clogged.. New o2 sensors might help too. ( use ONLY NTK brand or you'll be sorry !)
Which rear end gear ratio do you have ? I have the 3.73 and although it tows my 17 foot Skeeter just fine....it isnt going to win any uphill races while towing it.
I hope you have a tranny cooler on it if you are towing.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 8 Old 09-24-2013, 10:47 AM
zander21510
Have you towed before? The 4.0 doesn't feel like it has any power pulling anything anyways, I towed probably a 1000lb trailer or less from Uhaul, and it was struggling.
zander21510 is offline
post #4 of 8 Old 09-24-2013, 10:59 AM
Oldfrog
2007 WK
Yup...this is true. Punch in your OD button on the dash too. Just get a running start on hills. I "hit" an intracoastal canal bridge last month in south Louisiana while towing my boat at 75 mph so I could make it over the top. Air off, OD switch pushed in and hauling azz...
that's WITH the 3.73.
Oldfrog is offline
post #5 of 8 Old 09-24-2013, 11:01 AM Thread Starter
mobilehomer
Thanks, guys. I reckon it's just something I will have to put up with. Did not try OD switch.
post #6 of 8 Old 09-24-2013, 11:20 AM
Josef86
My old worn out 4wd 4.0L XJ towed better than my uncles properly maintained 2wd 4.0l ZJ.
I've towed our Glastron GT225 which is 22 ft, and 4400lbs w/trailer. My concern on that trip was brakes(which did well) and wheelbase(which was scary as **** even on stock set up). But I've got the 5.2l and 3.73s, so getting it going isn't an issue. Its the stopping that will always concern me.
Once I get out of Houston...I don't have to stress the brakes.
Josef86 is offline
post #7 of 8 Old 09-24-2013, 11:54 AM
zander21510
Probably because the 4.0 can barely move the ZJ's heavy *** by itself anyway lol.
post #8 of 8 Old 09-24-2013, 03:18 PM
Oldfrog
2007 WK
Yeah, but I bet there are more 4.0s around with 250K on them than 5.2s.
Oldfrog is offline
