'96 ZJ - Wipers Stop Almost half way up. - JeepForum.com
post #1 of 8 Old 06-13-2011, 11:29 PM Thread Starter
muzicman82
2011 WK
OK, I know this has been posted a few times, but the info I've seen says it's probably the relay. I have verified that the problem is NOT the relay.
Delay seems to work although it only pauses for a second or less.
Should I replace the motor and go from there?
2011 Jeep Grand Cherokee Laredo - 3.6L V6
105,000 (12/27/15)
1996 Jeep Grand Cherokee Limited - 5.2L V8
366,700 miles (4/21/12) (Laid to rest, but worked)
muzicman82 is offline
post #2 of 8 Old 06-13-2011, 11:44 PM
jayeepee
change the motor and check to see if those arms arent binding anywhere!
jayeepee is offline
post #3 of 8 Old 06-13-2011, 11:47 PM
jayeepee
if it was the relay... they act just like a fuse either you have power or you dont... FYI
jayeepee is offline
post #4 of 8 Old 06-14-2011, 12:12 AM
newfieZJ
Use this process on the motor before replacing it , should work . http://www.nagca.com/grandtech/rearwiperrepair.htm
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #5 of 8 Old 06-14-2011, 08:59 AM
MaintMech
Old and in the way
MaintMech's Avatar
http://www.jeepforum.com/forum/f13/i...roject-279739/
And you can take a look at this thread. Might help.
Good luck!!
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #6 of 8 Old 06-14-2011, 09:01 AM Thread Starter
muzicman82
2011 WK
Good luck!!
That is for earlier model ZJs. I believe the wipers on this model are controlled by the Body Control Module. I already opened that up and it looks fine.
105,000 (12/27/15)
post #7 of 8 Old 06-14-2011, 07:21 PM Thread Starter
muzicman82
2011 WK
I noticed in the wiring diagrams that there is a circuit for "Wiper Park Switch Sense" from the Body Control Module. Anyone have any idea how I could easily test this circuit? Is it just contact closure or does the BCM send +12V or something out for this? I'm wondering if this is supposed to tell the motor to pull the wiper back down to "Park", but the circuit isn't working.
Or does this function just go bad in the motor?
I guess I can replace the motor anyway and go from there.
105,000 (12/27/15)
post #8 of 8 Old 07-10-2011, 04:54 PM Thread Starter
muzicman82
2011 WK
Hi all,
Just replaced the motor today and everything seems fine!
Does anyone know where to get just the bracket that attached to the post on the motor? That bracket is a tiny bit worn due to a loose retaining nut. I don't want to have to replace the whole assembly, unless I can get that cheap.
105,000 (12/27/15)
AC issue...half cold & half hot AZTJ WK Grand Cherokee & XK Commander Forum 35 05-01-2011 08:30 AM
dashboard lights half bright/half dim cpttomasz ZJ Grand Cherokee Forum 3 03-13-2010 11:55 AM
Wipers WhiteOut ZJ Grand Cherokee Forum 6 04-07-2008 02:16 PM
Stop lights stop working on 2002 Larado dhands ZJ Grand Cherokee Forum 1 08-28-2006 11:35 AM
Delay setting operates wipers low, and wipers stop in random position when turned off Hubjeep ZJ Grand Cherokee Forum 1 08-10-2006 11:41 PM
